Learn how to integrate WooCommerce with Stripe using Pabbly Connect. This detailed tutorial walks you through the setup process step by step. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
Accessing Pabbly Connect for WooCommerce Stripe Integration
To start integrating WooCommerce with Stripe, first access Pabbly Connect. This powerful integration platform allows you to automate workflows between these applications seamlessly. Begin by visiting the Pabbly Connect website and logging into your account or creating a new one.
Once logged in, navigate to the dashboard where you can create a new workflow. Select ‘Create Workflow’ to initiate the integration process. Here are the basic steps you will follow:
  • Log into your Pabbly Connect account.
  • Click on ‘Create Workflow’.
  • Name your workflow for easy identification.
With your workflow created, you are now ready to set up the integration between WooCommerce and Stripe through Pabbly Connect.
Setting Up the Trigger in Pabbly Connect
The next step in the WooCommerce Stripe integration is to set up a trigger that will initiate the workflow whenever a successful payment is made. In Pabbly Connect, select ‘Stripe’ as the trigger application and choose the ‘New Payment’ event.
After selecting the trigger event, you will need to connect your Stripe account to Pabbly Connect. Follow these steps to authenticate your Stripe account:
  • Click on ‘Connect with Stripe’.
  • Log into your Stripe account to authorize the connection.
  • Return to Pabbly Connect and test the connection.
Once your Stripe account is connected, you will be able to retrieve payment details for successful transactions, which will be used to create WooCommerce orders.
Creating WooCommerce Orders from Stripe Payments
After setting up the trigger, the next step is to create an action that will generate a WooCommerce order based on the payment information received from Stripe. Select ‘WooCommerce’ as the action application in Pabbly Connect.
Choose the ‘Create Order’ action event. You will be prompted to connect your WooCommerce account. Follow these steps:
Click on ‘Connect with WooCommerce’. Enter your WooCommerce store URL and API keys. Authorize the connection and test it.
Once connected, map the fields from the Stripe payment data to the WooCommerce order fields. This will ensure that all relevant details from the payment are included in the order.
Testing the Integration
With both the trigger and action set up, it’s crucial to test the integration to ensure everything works as expected. In Pabbly Connect, you can test the workflow by simulating a Stripe payment.
Follow these steps for testing:
Go to the workflow dashboard. Click on ‘Test Workflow’. Check for a successful order creation in WooCommerce.
Once the test is successful, your integration between WooCommerce and Stripe using Pabbly Connect is complete. You can now automate the process of creating orders from successful payments effortlessly.
In conclusion, using Pabbly Connect to integrate WooCommerce with Stripe allows for seamless order creation from successful payments. This automation simplifies your workflow and enhances efficiency in managing orders.
