Learn how to automate WhatsApp marketing for your photography studio business using Pabbly Connect and Facebook Lead Ads. Step-by-step guide included. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To start with WhatsApp marketing automation for your photography studio business, you need to access Pabbly Connect. This platform allows you to integrate various applications seamlessly.
Begin by visiting the Pabbly website and either sign in or create a free account. Once logged in, you will find the option to access Pabbly Connect from the dashboard, allowing you to create automated workflows.
In this section, you will create a new workflow in Pabbly Connect to automate the process of sending WhatsApp messages when new leads are generated from Facebook Lead Ads.
Click on the ‘Create Workflow’ button and name your workflow appropriately to reflect its purpose. For instance, you can name it ‘WhatsApp Message for New Leads’. Save it in your desired folder within Pabbly Connect.
- Click on ‘Create Workflow’.
- Name your workflow.
- Select a folder to save it.
After creating the workflow, you will see two main sections: Trigger and Action. The Trigger will initiate the workflow when a new lead is generated.
3. Setting Up Trigger with Facebook Lead Ads
Now, you will set up the Trigger in Pabbly Connect using Facebook Lead Ads. This step is crucial as it defines when the automation begins.
Select Facebook Lead Ads as your Trigger application and choose the event ‘New Lead Instant’. Connect your Facebook account by following the prompts to authorize access.
- Select Facebook Lead Ads as the Trigger application.
- Choose ‘New Lead Instant’ as the trigger event.
- Connect your Facebook account for access.
Make sure your lead generation form on Facebook is live, as this will be essential for testing the integration later.
4. Configuring Action to Send WhatsApp Messages
After setting up the Trigger, the next step is to configure the Action in Pabbly Connect to send WhatsApp messages using WATI.
Select WATI as your Action application and choose the event ‘Send Template Message’. You will need to connect your WATI account by providing the API endpoint and access token.
Choose WATI as the Action application. Select ‘Send Template Message’ as the action event. Provide API endpoint and access token for WATI.
Ensure that you map the WhatsApp number and template correctly to send personalized messages to your leads.
Finally, it’s time to test your integration in Pabbly Connect. This step ensures that everything functions as intended.
Generate a sample lead submission through your Facebook Lead Ads and check if the automated WhatsApp message is sent successfully. Monitor the responses in both Pabbly Connect and WhatsApp to confirm the integration is working.
Submit a sample lead through Facebook Lead Ads. Check Pabbly Connect for the response. Verify the WhatsApp message received.
By following these steps, you will have successfully automated WhatsApp marketing for your photography studio business using Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to automate WhatsApp marketing for your photography studio business through Facebook Lead Ads. By following the steps outlined, you can enhance your lead engagement effectively.
