Topics Covered:-
- What is template engine?
- How to use Template Engine?
- Sending variables to EJS and show on frontend
The Template Engine is used to merge HTML page with the data from your program. The engine is simple and powerful.
At runtime, it replaces variables in a template file with actual values and transforms the template into an HTML file sent to the client.
For Eg:-
Welcome <%= username %>
Here username is a variable.It will replace the username with the value received from the backend. Say username variable contains “Rahul” value then the output will be:-
Welcome Rahul
There are number of template engines available some of them are given below:-
- EJS
- Jade(pug)
- Vash
- Mustache
- Dust.js
- Nunjucks
- Handlebars
- ATPL
- HAML
In this Tutorial, we are going to learn about EJS Template Engine. EJS Stands for Embedded JavaScript.
HOW TO USE TEMPLATE ENGINE
- First Install EJS into your project using NPM as below.
npm install --save ejs
- Create a folder named “Views” in project’s root directory Because by default Express.js searches all the views(templates) in the views folder under the root folder. If you don’t want your folder to be named as views you can change name using views property in express.
eg : the name of your folder is myviews then in our main file in this case app.js we write app.set(‘views’,./myviews); - All the templates file are saved with template engine’s extension and in views folder. Here we are using EJS so all templates are saved with .ejs extension in views folder.
USING TEMPLATE ENGINE
EJS files are simple to write because in this file we write simple HTML and write logic, backend variables between these tags:-
- <% %>(to write logics)
- <%= %>( when we want to display content use this)
Here in this tutorial, we have two files one is main JS file i.e. app.js , which creates a server and one template file( display.ejs ).
1. In app.js first create a basic server like this:
var express = require("express"); //requiring express module
var app = express(); //creating express instance
app.get("/", function(req, res) {
res.send("hello");
app.listen(3000, function() {
console.log("Node server is running..");
2. Now to send templates to frontend, first we set the view engine as follows:-
app.set("view engine","ejs");
Add the following line to app.js
3. After setting the view engine we create a simple display.ejs file in view folder with a simple ‘hello user’ message in it.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<meta http-equiv="X-UA-Compatible" content="ie=edge">
<title>templates</title>
</head>
<body>
<p>Hello User</p>
</body>
</html>
4. Now to send the file to frontend we have a function called i.e. res.render() , it renders a view and sends the rendered HTML string to the client.
To render our file in previous code we replace res.send(“hello”); with res.render(‘display’) ;
var express = require('express');
app.get('/', function (req, res) {
//rendering our ejs template
res.render('demo');
var server = app.listen(3000, function () {
console.log('Node server is running..');
Run the following code as “node app.js” in terminal and press enter:-
c:\Express-project\project>node app.js
The server is now started you can see the message in terminal
point your browser to http://localhost:3000 and you will see the message “Hello User”.
If we want to send data from backend and use it in EJS file we can do this in the following manner:-
Here instead of user in our display.ejs file I want to specify the name of the user. We can send data where we are rendering the file.
Eg:- res.render(‘display’,{variable_name:’value’});
Say the username is ‘Rahul’ then our code will be:-
res.render('display',{user:'Rahul'});
And to display this on front end we write this user variable inside <%= %> like this:-
<p>Hello <%= user%></p>
Now restart the server and run the code again and on refreshing the page you will see Hello Rahul instead of Hello User.
Sending Arrays or Objects(JSON data)
-We can send any sort of data to the frontend. Suppose if I have a JSON data having an array named authors[] of author object having name and article, and I want to display it on frontend via a list, I can send an array to EJS and then loop through it and display the data. For this follow the given example:-
app.set("view engine", "ejs");
var authors = [
article: "node.js"
article: "express.js"
article: "mongoose"
res.render("display", { authors });
var server = app.listen(3000, function() {
-Copy and paste this code in your app.js file here I have created an array named “authors” and I have rendered it with the ejs file. Note:- you can send the data by assigning it to a variable{values: data} or directly{data} in direct case you can access it with data and by assigning it you can access it with whatever variable you have assigned in given example by values.
Now to access the author array in EJS follow the below EJS code:-
<!DOCTYPE html>
<html lang="en">
<head>
<title>Document</title>
</head>
<body>
<h3>Name Of Authors</h3>
<ul>
<!-- looping through authors array -->
<% authors.forEach(function(author){ %>
<li>
<%= author.name %>
</li>
</ul>
</body>
</html>
Here In the above EJS code, we have used a forEach loop to iterate through “authors” array and to access data of authors array one by one.
Save app.js and display.ejs with the following code and then run the code, now as you refresh the web page(http://localhost:3000) you will see the following output.
Final Output:-
Learn More-
