Mongoose allows us to easily access MongoDB commands for CRUD. There is always a need to create, read, update, and delete information all the time. CRUD is the most necessary thing out there to do so.
Topics Covered
- Initial steps to follow while working on mongoose
- Defining Schema and Model
- Inserting data into Database
- Query the Database
- Read
- Update
- Delete
Step 1: Be sure you have MongoDB and Node.js installed.
Step 2: Install Mongoose from the command line.
$ npm install mongoose --save
Step 3: Include mongoose in our project.
var mongoose = require('mongoose');
Step 4: Connect to a MongoDB database.
mongoose.connect('mongodb://localhost/test');
Step 5: We have a pending connection to the test database running on localhost. Now to check the pending connection:
mongoose.connection.on('connected', function () {
console.log("mongoose connection ready" + url);
mongoose.connection.on('error', function () {
console.log("mongoose connection error" + url);
mongoose.connection.on('disconnected', function () {
console.log("mongoose connection disconnected" + url);
Step 6: Define mongoose Model and Schema.
In Mongoose, everything is derived from a Schema.
var testSchema = mongoose.Schema({
username: {
type: String,
required: true,
unique: true
password: {
type: String,
required: true
admin: Boolean
A schema with properties name, username, password, and admin. Which will be of types string, string, string and boolean respectively.
SchemaTypes in mongoose :
- String
- Number
- DateBuffer
- Boolean
- Mixed
- ObjectId
- Array
Compiling our schema into a Model
var Test = mongoose.model('Test', testSchema, 'collection_name');
A combined sample with both schema and model
//require mongoose
var Schema = mongoose.Schema;
// create a schema
var TestSchema = Schema({
username: {
type: String,
required: true,
unique: true
password:
type: String,
required: true
admin: Boolean
// the schema is useless, we need to create a model using it
var Test= mongoose.model('Test', TestSchema, 'collection_name');
// make this available to our users in our Node applications
module.exports = Test;
We still haven’t saved anything to MongoDB. To save the Test and data we had created earlier, we need to use a built-in method Create on mongoose Model.
Create
// grab the test model
var Test = mongoose.model('Test');
// create a JSON data
var data = {
username: 'user',
password: 'password',
admin: true
// create data using test we have created in the model
Test
.create(data, function (err, result) {
if (err) throw err;
console.log('Test created!');
Query the Database
Following are few examples, to query the database that we have created :
Read
// get all the data from test
Test
.find({}, function (err, data) {
if (err) throw err;
// object of all the test
console.log(data);
Find One :
// get newuser from model test
Test
.find({ username: 'newuser' }, function (err, data) {
if (err) throw err;
// object of the test
console.log(data);
Find By ID :
// get the test with ID of 1
Test
.findById(1, function (err, data) {
if (err) throw err;
// show the test with ID of 1
console.log(data);
Update
Find a specific data from test and modify that particular attribute.
Find By Id and Update :
// find test with id 3
// update username to admin
Test
.findByIdAndUpdate(3, { username: 'admin' }, function (err, data) {
if (err) throw err;
// we have the updated data returned to us
console.log(data);
Find and Update :
// find test newuser
// update him to admin
Test
.findOneAndUpdate({ username: 'newuser' }, { username: 'admin' }, function (err, data) {
if (err) throw err;
console.log(data);
Delete
Find By ID and Remove :
// find the test with id 4 and remove
Test
.findByIdAndRemove(4, function (err) {
if (err) throw err;
// we have deleted the user
console.log('data deleted!');
Find and Remove :
// find test where username is admin and remove
Test
.findOneAndRemove({ username: 'admin' }, function (err) {
if (err) throw err;
Learn More:
