Learn how to integrate Trello and Discord using Pabbly Connect. This guide provides a detailed tutorial on sending Discord messages from new Trello cards. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Access Pabbly Connect for Trello and Discord Integration
To begin the integration of Trello and Discord, first access Pabbly Connect. This platform allows seamless data transfer between different applications, including Trello and Discord.
Start by visiting the Pabbly Connect website. Here’s how to get started:
  • Go to the Pabbly Connect homepage.
  • Click on the ‘Sign In’ button to access your account or create a new account if you don’t have one.
  • Once logged in, navigate to the ‘Connect’ section.
After logging in, you will be directed to the Pabbly Connect dashboard, where you can create your workflow.
Next, create a new workflow in Pabbly Connect to facilitate the integration. This workflow will trigger a message in Discord whenever a new card is created in Trello.
Follow these steps to create your workflow:
  • Name your workflow, e.g., ‘Trello to Discord’.
  • Select Trello as the trigger app.
  • Choose the trigger event as ‘New Card Created’.
This setup allows Pabbly Connect to listen for new cards in Trello and act accordingly to send messages to Discord.
3. Connect Trello to Pabbly Connect
After setting up your workflow, the next step is to connect Trello to Pabbly Connect. This connection is essential for triggering actions based on new cards created in Trello.
To connect Trello, you will need your Trello username, API key, and token. Here’s how to obtain these credentials:
Log into your Trello account and go to your profile settings. Copy your username from the profile section. Generate your API key and token using the provided links in Pabbly Connect.
Paste these credentials into Pabbly Connect to establish the connection. Click on ‘Save’ to finalize the integration with Trello.
4. Set Up Discord in Pabbly Connect
Now that Trello is connected, it’s time to set up Discord in Pabbly Connect. This step ensures that messages are sent to the right channel whenever a new Trello card is created.
To integrate Discord, follow these steps:
Choose Discord as the action app in Pabbly Connect. Select the action event as ‘Send Channel Message’. Connect to your Discord account and authorize Pabbly Connect. Map the webhook ID and token from Discord into Pabbly Connect.
This integration allows Pabbly Connect to send messages to your specified Discord channel based on the Trello card creation event.
5. Test Your Integration
The final step is to test your integration to ensure everything is working correctly. This involves creating a new card in Trello and checking if a message is sent to Discord via Pabbly Connect.
To test your integration:
Create a new card in the specified Trello list. Check the Discord channel for the message from Pabbly Connect.
If the message appears in Discord, your integration is successful! You can now automate notifications from Trello to Discord seamlessly using Pabbly Connect.
In conclusion, integrating Trello and Discord using Pabbly Connect allows you to automate notifications efficiently. By following the steps outlined in this tutorial, you can ensure that every new Trello card triggers a message in your Discord channel, enhancing team communication.
