Learn how to automate your Elementor forms with Pabbly Connect. Discover 15 powerful integrations to streamline your workflows and enhance productivity. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Sending WhatsApp Messages on Elementor Form Submission
In this section, we will learn how to send WhatsApp messages automatically using Pabbly Connect when a user submits an Elementor form. This integration allows you to notify the submitter instantly, enhancing customer engagement.
To set this up, first, create a new workflow in Pabbly Connect and select Elementor as the trigger app. Choose ‘New Form Submission’ as the trigger event, and copy the provided webhook URL. Then, go to your Elementor form settings and paste this URL into the Webhook field under ‘Actions After Submit’.
- Create a new workflow in Pabbly Connect.
- Select Elementor as the trigger app.
- Paste the webhook URL into your Elementor form settings.
Once the form is submitted, Pabbly Connect will capture the response, allowing you to send a WhatsApp message using the Interact app. Map the form fields to the message template in Interact, and your automation is complete!
2. Creating Google Calendar Events from Elementor Form Submissions
This section explains how to create Google Calendar events automatically when a new form is submitted via Elementor using Pabbly Connect. This is particularly useful for appointment bookings or event registrations.
Start by setting up a new workflow in Pabbly Connect with Elementor as the trigger. Select ‘New Form Submission’ and copy the webhook URL. In your Elementor form, paste this URL in the Webhook field under ‘Actions After Submit’. This allows Pabbly Connect to capture the form submission data.
- Set up a new workflow in Pabbly Connect.
- Select Google Calendar as the action app.
- Map the form submission fields to the event details.
After submitting the form, Pabbly Connect will create a new event in Google Calendar with the details provided in the form, ensuring all appointments are tracked efficiently.
3. Adding MailChimp Subscribers from Elementor Form Submissions
In this section, we will explore how to automatically add subscribers to MailChimp from Elementor form submissions using Pabbly Connect. This integration streamlines your email marketing efforts.
Begin by creating a new workflow in Pabbly Connect and selecting Elementor as the trigger app. Choose ‘New Form Submission’ as the trigger event and copy the webhook URL. Paste this URL into your Elementor form settings under ‘Actions After Submit’ to enable data capture.
Create a new workflow in Pabbly Connect. Select MailChimp as the action app. Map the form fields to MailChimp subscriber details.
Once the form is submitted, Pabbly Connect will automatically add the subscriber to your MailChimp list, ensuring your email marketing campaigns are always up to date.
4. Creating Salesforce Contacts from Elementor Form Submissions
This section covers how to create contacts in Salesforce automatically when a new Elementor form is submitted, using Pabbly Connect. This integration helps manage leads more effectively.
Start by creating a new workflow in Pabbly Connect, selecting Elementor as the trigger app, and ‘New Form Submission’ as the trigger event. Copy the webhook URL and paste it into your Elementor form under ‘Actions After Submit’.
Set up a new workflow in Pabbly Connect. Select Salesforce as the action app. Map the form submission fields to Salesforce contact details.
After the form is submitted, Pabbly Connect will create a new contact in Salesforce with the details from the form, allowing for seamless lead management.
5. Creating Items in Monday.com from Elementor Form Submissions
In this final section, we will learn how to create items in Monday.com automatically from Elementor form submissions using Pabbly Connect. This integration helps keep your project management organized.
Create a new workflow in Pabbly Connect and select Elementor as the trigger app, choosing ‘New Form Submission’ as the trigger event. Copy the webhook URL and paste it into your Elementor form settings under ‘Actions After Submit’.
Create a new workflow in Pabbly Connect. Select Monday.com as the action app. Map the form fields to the item details in Monday.com.
When the form is submitted, Pabbly Connect will create a new item in Monday.com, keeping your tasks organized and up to date.
In this guide, we explored how to automate Elementor form submissions using Pabbly Connect. By integrating with various applications like WhatsApp, Google Calendar, MailChimp, Salesforce, and Monday.com, you can streamline your workflows and enhance productivity.
