Discover how to automate Telegram tasks using Pabbly Connect. This complete guide covers integration with Google Sheets, Discord, and more, step by step. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Introduction to Pabbly Connect for Telegram Automations
Pabbly Connect serves as the central platform for automating Telegram tasks. This guide will explore various automations that can be set up using Pabbly Connect, enhancing your Telegram experience. From sending alerts to posting updates, the integration possibilities are vast.
Using Pabbly Connect, you can seamlessly connect Telegram with other applications like Google Sheets, Discord, and more. This enables you to automate repetitive tasks, ensuring that your workflow remains efficient and organized.
2. Setting Up Trading View Alerts to Telegram Using Pabbly Connect
To start automating your Trading View alerts to Telegram, first log into your Pabbly Connect account. Create a new workflow by selecting ‘Create Workflow’ and naming it appropriately, such as ‘Trading View to Telegram’.
  • Select Trading View as the trigger application.
  • Choose ‘New Alert’ as the trigger event.
Next, go to your Trading View account and set up an alert. Paste the webhook URL into the alert settings. This will allow Trading View to send alerts to your Pabbly Connect workflow whenever the specified conditions are met.
3. Auto Forwarding Telegram Messages to Discord with Pabbly Connect
To automatically forward messages from Telegram to Discord, start by creating a new workflow in Pabbly Connect. Name it something like ‘Telegram to Discord’. This workflow will allow you to send messages received in Telegram directly to a Discord channel.
Set Telegram as the trigger application and select ‘Webhook Watch Updates’ as the event. Connect your Telegram bot by obtaining the token from BotFather. Once connected, create a new group in Telegram and add your bot as an admin.
  • Send a test message in Telegram to capture the webhook response.
  • Select Discord as the action application and choose ‘Send Channel Message’.
  • Map the captured message data to the Discord message field.
After saving the workflow, you will see that every new message in your Telegram group is automatically forwarded to your specified Discord channel, thanks to the automation capabilities of Pabbly Connect.
4. Posting New Tweets from Twitter to Telegram Using Pabbly Connect
To automate the process of posting new tweets from Twitter to Telegram, start by creating a new workflow in Pabbly Connect and name it ‘Twitter to Telegram’. This setup will ensure that any new tweet you post will also be shared with your Telegram followers.
In the trigger step, select Twitter as the application and ‘New Tweet’ as the event. Connect your Twitter account to Pabbly Connect, allowing it to access your tweets. Once connected, you can set up the action to send a message to Telegram.
Choose Telegram as the action application. Select ‘Send Text Message’ as the action event. Map the tweet text to the message field in Telegram.
With this setup, every time you tweet, the same message will be sent to your Telegram channel, keeping your audience updated without any extra effort.
5. Saving Telegram Files to Google Drive Automatically with Pabbly Connect
To save files received in Telegram to Google Drive automatically, begin by creating a new workflow in Pabbly Connect. Name it ‘Telegram to Google Drive’. This workflow will help you manage important files shared in Telegram.
Set Telegram as the trigger application and select ‘Webhook Watch Updates’ as the event. Connect your Telegram bot and ensure it has access to the group where files will be shared. Once the trigger is set up, create an action to upload files to Google Drive.
Choose Google Drive as the action application. Select ‘Upload File’ as the action event. Map the file URL from the Telegram trigger to the Google Drive upload field.
By completing this setup, any file shared in your Telegram group will be automatically saved to your Google Drive, ensuring that important documents are securely stored and easily accessible.
In this comprehensive guide, we explored how to use Pabbly Connect to automate various tasks within Telegram. From integrating Trading View alerts to saving files in Google Drive, the possibilities are endless. With Pabbly Connect, you can streamline your workflows and enhance productivity effortlessly.
