Learn how to automate multiple product sales in Razorpay with Pabbly Connect. Step-by-step guide for integrating Google Drive and Razorpay without coding. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
Access Pabbly Connect to Set Up Automation
To start automating processes with Razorpay, first access Pabbly Connect. This platform allows you to easily integrate multiple applications without any coding skills. Begin by visiting the Pabbly Connect homepage and signing in or signing up for a new account.
Once logged in, you will see the dashboard where you can create workflows. Click on the ‘Create Workflow’ option. You will be prompted to name your workflow, such as ‘Set Up Automation for Multiple Products in Razorpay’ and select a folder for organization. This setup is crucial as it helps in managing different workflows effectively.
Set Up Trigger for Razorpay Payments
In this section, you will configure the trigger for your automation using Pabbly Connect. Select Razorpay as your trigger application. The trigger event should be set to ‘Payment Captured’. This means the workflow will start when a payment is successfully processed through Razorpay.
After selecting Razorpay, you will receive a webhook URL. This URL is essential for connecting Razorpay with Pabbly Connect. Go to your Razorpay dashboard, navigate to ‘Accounts and Settings’, and then to ‘Webhooks’. Here, click on ‘Add New Webhook’ and paste the copied URL. Ensure you select the ‘Payment Captured’ event as the active event before saving the webhook.
Test Payment to Capture Response
After setting up the webhook in Razorpay, it’s time to test the payment process. This step is crucial to ensure that Pabbly Connect receives the payment details correctly. Make a test payment using the payment page for your digital product. Once the payment is processed, return to Pabbly Connect to see if it captures the response.
Upon successful payment, you should see the payment details in your Pabbly Connect dashboard. This information includes the payment status, customer details, and amount. It’s essential to verify that the payment amount matches the product price to ensure the correct workflow will execute.
Set Up Routing and Actions for Product Access
Now that you have captured the payment response, you need to set up routing in Pabbly Connect. This allows you to differentiate between products based on the payment amount. Use the Router feature to create two different routes: one for the Digital Dynamics course and another for Java notes.
  • Create a condition in the first route for payments of 9999 for Digital Dynamics.
  • In the second route, set the condition for payments of 3999 for Java notes.
  • For each route, add action steps to share the respective files from Google Drive.
For the action steps, select Google Drive as the application and set the action event to ‘Share File’. Map the email address of the customer from the Razorpay response to ensure they receive access to the correct course materials. This setup allows for seamless delivery of digital products based on the payment received.
Final Testing and Verification of Automation
After configuring all routes and actions, it’s time to test the entire workflow. Make a test payment for both courses using Razorpay. Verify that upon successful payment, the correct course access is granted to the customer via Google Drive. This is the final check to ensure that Pabbly Connect is functioning as intended.
Once you confirm that the automation works for both products, you can confidently use this setup for actual transactions. This process exemplifies how Pabbly Connect simplifies integration between multiple applications, allowing for efficient management of digital product sales.
In this tutorial, we explored how to set up automation for multiple products in Razorpay using Pabbly Connect. The integration allows for automatic access to digital products upon payment, streamlining your sales process. This setup is ideal for anyone looking to enhance their online sales efficiency.
