Learn how to send WhatsApp messages to Facebook leads for sustainable products using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To send WhatsApp messages to Facebook leads for sustainable products, you first need to access Pabbly Connect. This platform enables seamless integration between various applications, making it essential for your automation needs.
Navigate to the Pabbly Connect homepage by entering the URL in your browser. Here, you will find options to sign in or sign up. If you are a new user, click on ‘Sign Up Free’ to create an account and explore the features available.
Once you are signed in to Pabbly Connect, you will see the dashboard. Click on the ‘Create Workflow’ button located at the top right corner. This initiates the process of setting up your automation.
  • Give your workflow a name, such as ‘Green Horizon Facebook Lead Ads to WhatsApp Message’.
  • Select a folder for your workflow to keep it organized.
After creating the workflow, you will see the trigger and action setup options. The trigger application will be Facebook Lead Ads, and the action application will be WhatsApp Cloud API, allowing you to automate the message sending process.
3. Setting Up the Trigger with Facebook Lead Ads
To begin automation, you must set up the trigger in Pabbly Connect. Select Facebook Lead Ads as your trigger application and choose the event ‘New Lead Instant’. This ensures that the workflow activates whenever a new lead is generated.
Next, click on ‘Connect’, and if you don’t have an existing connection, select ‘Add New Connection’. Authorize your Facebook account and choose the relevant page named ‘Green Horizons’. After selecting the page, choose the lead form you created, such as the ‘Organic Product Form’.
4. Testing the Trigger Setup in Pabbly Connect
After selecting your lead form, click ‘Save and Send Test Request’ in Pabbly Connect. This action will prompt you to perform a test submission to ensure the connection works correctly. Use the Meta for Developers tool to submit a test lead.
  • Select your Facebook page and lead form in the Meta tool.
  • Enter dummy data for the test lead, including a name and phone number.
  • Submit the form to generate a test lead.
Return to Pabbly Connect to confirm that you have received the response with the lead’s details, ensuring that the trigger setup is successful.
5. Setting Up the Action with WhatsApp Cloud API
Now that the trigger is set up, it’s time to configure the action in Pabbly Connect. Select WhatsApp Cloud API as your action application and choose the event ‘Send Template Message’. Click on ‘Connect’ to establish a connection.
You will need to enter your temporary access token, phone number ID, and WhatsApp Business Account ID from your WhatsApp Cloud API setup. After pasting these details, select your message template, such as ‘Facebook Leads Message’. This template contains dynamic variables that will personalize the message sent to each lead.
Before finalizing the setup, ensure you map the recipient’s mobile number and other variables from the Facebook lead data. Click ‘Save and Send Test Request’ to send a test message. Check your WhatsApp to confirm that the message has been successfully received, completing the integration process using Pabbly Connect.
This tutorial detailed how to send WhatsApp messages to Facebook leads for sustainable products using Pabbly Connect. By following these steps, you can automate your lead nurturing process effectively and efficiently.
