Learn how to integrate Facebook Lead Ads with Member Vault using Pabbly Connect for seamless automation. Follow our step-by-step tutorial for effective integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To begin integrating Facebook Lead Ads and Member Vault, first access Pabbly Connect. This platform allows you to automate processes without any coding skills.
If you are new to Pabbly Connect, sign up to create an account. Existing users can log in directly. Once logged in, you will have access to 100 free tasks each month to test your automations.
After logging into Pabbly Connect, navigate to the dashboard and click on the ‘Create Workflow’ button. A dialog box will appear prompting you to name your workflow.
  • Choose a descriptive name for your workflow, such as ‘Add Facebook Leads to Member Vault’.
Upon creation, you will see options for setting up a trigger and an action. The trigger will be Facebook Lead Ads, while the action will be Member Vault.
3. Setting Up Facebook Lead Ads as a Trigger
In this step, you will configure Facebook Lead Ads as the trigger in Pabbly Connect. Click on the trigger application and select ‘Facebook Lead Ads’. The trigger event should be set to ‘New Lead Instant’.
Next, connect your Facebook account by clicking on ‘Connect’. You will need to authorize Pabbly Connect to access your Facebook account. After successful authorization, select the Facebook page associated with your lead ads.
  • Choose the specific lead generation form linked to the page.
  • Click on ‘Save and Send Test Request’ to confirm the integration.
This step ensures that Pabbly Connect captures lead data correctly from Facebook Lead Ads.
4. Configuring Member Vault as an Action
Now that you have set up the trigger, it is time to define the action application, which is Member Vault in Pabbly Connect. Select Member Vault and choose the action event as ‘Add User’.
Next, you will need to connect your Member Vault account. This requires entering your API key and subdomain, which can be found in your Member Vault account settings under Integrations.
Copy the API key and paste it into the corresponding field in Pabbly Connect. Enter the subdomain of your Member Vault account.
Once the connection is established, you will need to map the data fields such as email address, first name, last name, and course ID to ensure the user is added correctly.
With the trigger and action set up in Pabbly Connect, it is crucial to test the integration. Use the Facebook Lead Ads debug tool to create a test lead and submit the form.
Return to Pabbly Connect and check if the webhook response has captured the lead information. If successful, proceed to finalize the mapping of the user data in Member Vault.
Ensure that all fields are correctly populated with the lead’s information. Click on ‘Save and Send Test Request’ to complete the user addition.
Finally, log into your Member Vault account to verify that the new user has been successfully added to the specified course, confirming the integration is successful.
In this tutorial, we explored how to integrate Facebook Lead Ads with Member Vault using Pabbly Connect. By following the detailed steps, you can automate user enrollment seamlessly, enhancing your workflow efficiency.
