Learn how to integrate Zoho Campaigns with Webflow using Pabbly Connect. This step-by-step tutorial covers the entire process of automating subscriber updates. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
Pabbly Connect is the central platform that facilitates the integration between Webflow and Zoho Campaigns. To start, visit the Pabbly Connect website and sign in to your account. If you are a new user, you can sign up for free and get 100 tasks each month. using Pabbly Connect
Once signed in, you will see the ‘All P Apps’ window. Click on the ‘Access Now’ button for Pabbly Connect. This action takes you to the Pabbly Connect dashboard, where you can create a new workflow.
To create a workflow, click on the ‘Create Workflow’ button located in the top right corner. A dialog box will appear prompting you to enter a name for your workflow. I am going to name it ‘Add or Update Zoho Campaign Subscriber on Webflow Form Submission’. using Pabbly Connect
  • Choose the folder named ‘Zoho Campaigns Automation’.
After naming your workflow and selecting the folder, click the ‘Create’ button. This will set up your workflow for the automation process.
In the newly created workflow, you will see two sections: Trigger and Action. The trigger is essential as it captures the event that starts your automation process. For the trigger application, select ‘Webflow V2’. using Pabbly Connect
Next, choose the trigger event as ‘Form Submitted’. Click on the ‘Connect’ button to establish a connection. A window will appear prompting you to add a new connection or select an existing one.
  • Click on ‘Add New Connection’.
  • Enter the API token from your Webflow account.
Once the connection is established, select the Site ID corresponding to your Webflow site where the form is located. Click on ‘Save and Test Request’ to verify the connection.
4. Testing the Webflow Form Submission
To test the integration, perform a test submission on your Webflow form. Fill out the form with sample data, such as first name, last name, email, and organization. After submitting, you will see a confirmation message. using Pabbly Connect
Return to Pabbly Connect and check if the test submission was captured. You should see the details of the submitted form in the trigger section. This confirms that the connection between Webflow and Pabbly Connect is successful.
5. Setting Up the Action in Pabbly Connect
Now that the trigger is set up, it’s time to configure the action. For the action application, select ‘Zoho Campaigns’ and choose the action event as ‘Add or Update Subscriber’. Click on the ‘Connect’ button to establish a connection with Zoho Campaigns. using Pabbly Connect
When prompted, enter the domain from your Zoho Campaigns account. After entering the domain, click on the ‘Save’ button. You will need to authorize this connection to allow Pabbly Connect to manage your subscribers.
Select the list where you want to add the subscriber. Map the required fields such as email, first name, and last name from the previous step.
Finally, click on ‘Save and Send Test Request’. A confirmation email will be sent to the new subscriber, verifying that they have been added to your Zoho Campaigns account.
This tutorial demonstrated how to automate the process of adding or updating Zoho Campaigns subscribers through Webflow form submissions using Pabbly Connect. By following these steps, you can streamline your email marketing efforts and ensure timely communication with your leads.
