1. Overview of WooCommerce and Xero Integration
Integrating WooCommerce with Xero improves your eCommerce operations. WooCommerce is a popular eCommerce platform, while Xero is an online accounting software.
This integration allows automatic data transfer of new WooCommerce orders as invoices in Xero. However, direct integration isn’t available, necessitating a third-party tool.
2. Getting Started with Pabbly Connect
Begin by visiting the Pabbly Connect website. Click on “Sign In” to access your dashboard.
If you don’t have an account, you can create one in just two minutes. Once logged in, locate the “Connect” section and click “Access Now”.
3. Creating a New Workflow
To create a workflow, click on “Create a New Workflow”. Enter the workflow name, such as “WooCommerce to Xero” and click “Save”.
This will open the trigger window. Change the app from “Webhook” to “WooCommerce” and select “New Order Created” as the method.
4. Setting Up Webhooks in WooCommerce
Navigate to your WooCommerce settings and click on the “Advanced” tab. Here, you will find an option for “Webhooks”.
Click on “Add Webhook” and provide a name. Change the status to “Active” and set the topic to “Order Created”.
Copy the delivery URL from Pabbly Connect and paste it into the webhook settings in WooCommerce, then save the webhook.
5. Testing the Integration
After saving the webhook, go back to Pabbly Connect and click on “Capture Webhook Response”. This will allow you to test the integration.
Now, create a test order in WooCommerce. Fill in the customer details and complete the purchase.
Return to Pabbly Connect to see if the data has been captured successfully. If successful, you will see the customer details populated.
Integrating WooCommerce with Xero using Pabbly Connect automates invoice creation, ensuring seamless financial management for your eCommerce business.
- Know more about Pabbly Connect – Automate workflows effortlessly!
