Learn how to integrate WooCommerce with Campaign Monitor using Pabbly Connect to automate customer subscriptions seamlessly. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Introduction to WooCommerce and Campaign Monitor Integration
In this section, we will explore how to integrate WooCommerce with Campaign Monitor using Pabbly Connect. WooCommerce is an online store setup software, while Campaign Monitor is an email marketing tool. This integration allows you to automatically add new customers from WooCommerce as subscribers in Campaign Monitor.
The native integration between WooCommerce and Campaign Monitor has limitations. Therefore, utilizing Pabbly Connect simplifies the process of transferring data seamlessly from WooCommerce to Campaign Monitor without any coding knowledge required.
2. Setting Up Pabbly Connect for Integration
To begin the integration, access Pabbly Connect by visiting the website and signing in to your account. If you do not have an account, you can create one for free in just two minutes. Once logged in, navigate to the dashboard and create a new workflow.
- Click on the ‘Connect’ button.
- Select the option to create a new workflow.
- Name the workflow as ‘WooCommerce to Campaign Monitor’ and click ‘Create’.
Now, choose WooCommerce as the application and select the trigger method as ‘New Customer Created’. This method will trigger the automation whenever a new customer is added to WooCommerce.
3. Configuring WooCommerce Webhook in Pabbly Connect
After selecting the trigger method, Pabbly Connect provides a webhook URL. Copy this URL as it will be used to connect WooCommerce to Pabbly Connect. Next, navigate to your WooCommerce settings, go to ‘Advanced’, and then to ‘Webhooks’.
- Click on ‘Add Webhook’.
- Name the webhook as ‘WooCommerce to Campaign Monitor’.
- Set the status to ‘Active’ and paste the webhook URL.
- Save the webhook settings.
Once the webhook is saved, return to Pabbly Connect and click on ‘Capture Webhook Response’ to start receiving data from WooCommerce.
4. Adding Subscribers to Campaign Monitor via Pabbly Connect
With the webhook response captured, you can now set up the action to add subscribers to Campaign Monitor. In Pabbly Connect, click on the plus button to add a new action and select Campaign Monitor as the application.
Select the action method as ‘Add Subscriber’. You will need to enter your Campaign Monitor API key, which can be obtained from your Campaign Monitor account settings under API Keys. Make sure to leave the password field blank and save the configuration.
Select the client account associated with your Campaign Monitor. Choose the appropriate list ID where the new subscribers will be added. Map the details such as email address and name from the webhook response.
After mapping the required fields, click on ‘Save and Send Test Request’ to ensure the integration is successful.
5. Testing the Integration of WooCommerce and Campaign Monitor
To verify that the integration works, create a new customer in WooCommerce. For example, register a new user with details such as username, email, and name. After registration, check the Campaign Monitor account to see if the subscriber was successfully added.
Upon refreshing the subscriber list in Campaign Monitor, you should see the new customer listed. This confirms that Pabbly Connect has successfully facilitated the integration between WooCommerce and Campaign Monitor, allowing for seamless subscriber management.
Every time a new customer is added in WooCommerce, Pabbly Connect ensures they are automatically subscribed to your Campaign Monitor list, streamlining your email marketing efforts.
Integrating WooCommerce with Campaign Monitor using Pabbly Connect allows for effortless management of your email marketing subscribers. This automation enhances your workflow, ensuring that every new customer is promptly added to your mailing list without manual intervention.
