Learn how to integrate WooCommerce with Bravo using Pabbly Connect. Follow our detailed tutorial to automate contact creation effortlessly. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To integrate WooCommerce with Bravo, the first step is to access Pabbly Connect. You can do this by visiting the Pabbly Connect website and signing in with your account. If you’re new, you can sign up for free to get started.
Once logged in, you will see a dashboard that showcases all your workflows. Click on the ‘Pabbly Connect’ option to access the integration features. Here, you can create a new workflow specifically for the WooCommerce and Bravo integration.
After accessing Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button and name it something descriptive, like ‘Create Bravo Contact from WooCommerce Order’. Select the appropriate folder to save this workflow.
- Click on the ‘Create’ button to initiate the workflow.
- You will see two boxes appear: one for the trigger and one for the action.
- Set WooCommerce as the trigger application with the event ‘New Order Created’.
This setup will ensure that every time a new order is placed in WooCommerce, it will trigger the action to create a contact in Bravo through Pabbly Connect.
3. Connecting WooCommerce to Pabbly Connect
To connect WooCommerce with Pabbly Connect, you need to set up a webhook URL provided by Pabbly. Go to your WooCommerce settings and navigate to the ‘Advanced’ section. Here, you will find the ‘Webhooks’ option.
- Click on ‘Add Webhook’ and paste the webhook URL from Pabbly Connect into the ‘Delivery URL’ field.
- Select the event ‘New Order Created’ for the webhook to trigger.
- Save the changes to update the webhook settings.
After saving, return to Pabbly Connect and click on ‘Recapture Webhook Response’ to test the connection. This will allow you to confirm that WooCommerce is successfully sending data to Pabbly Connect.
4. Setting Up Bravo as the Action Application
In the next step, you will set Bravo as the action application in Pabbly Connect. Choose ‘Create or Update Contact’ as the action event. If you have not connected Bravo yet, click on ‘Add New Connection’ and enter your API key from your Bravo account.
Ensure that you enter your domain correctly and save the connection. Once connected, you will need to map the fields from the WooCommerce order to the Bravo contact fields. This includes email, first name, last name, and any other relevant information.
5. Testing the Integration Between WooCommerce and Bravo
After setting up the action step, it’s time to test the integration. Place a test order in WooCommerce to see if the contact is created in Bravo. Ensure that all required fields are correctly mapped in Pabbly Connect.
Once you complete the test order and receive a confirmation message, check your Bravo account to verify if the new contact appears. If everything is set up correctly, you should see the contact created with the details from the WooCommerce order.
This tutorial detailed how to integrate WooCommerce with Bravo using Pabbly Connect. By following the steps outlined, you can automate the creation of contacts in Bravo whenever a new order is placed in WooCommerce, enhancing your workflow efficiency.
