Learn how to integrate WooCommerce and Abyssale using Pabbly Connect. Create banners automatically from WooCommerce coupons with this detailed tutorial. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Accessing Pabbly Connect for WooCommerce Integration
To start the integration process, access Pabbly Connect by typing ‘Pabbly.com’ in your browser. This platform allows you to connect various applications seamlessly.
After navigating to the website, hover over the ‘Products’ menu and select ‘Connect’. Click on ‘Sign In’ to access your dashboard. If you don’t have an account, you can create one for free in just a few minutes.
Once logged in, locate the ‘Create Workflow’ button at the top right corner of the dashboard. Click on it to initiate a new workflow. Name your workflow something descriptive, like ‘WooCommerce to Abyssale’.
  • Select ‘WooCommerce’ as the app to trigger the workflow.
  • Set the trigger event to ‘New Coupon Created’.
  • This will allow Pabbly Connect to respond when a new coupon is created in WooCommerce.
After setting up the trigger, click on ‘Create’ to proceed. This action will prepare Pabbly Connect to capture data from WooCommerce when a new coupon is created.
3. Setting Up WooCommerce Webhook
To link WooCommerce with Pabbly Connect, navigate to your WooCommerce settings. Click on ‘Settings’, then go to the ‘Advanced’ tab and select ‘Webhooks’. Here, you will add a new webhook.
  • Name the webhook appropriately, such as ‘WooCommerce to Abyssale’.
  • Set the status to ‘Active’ and the topic to ‘Coupon Created’.
  • Paste the webhook URL from Pabbly Connect into the delivery URL field.
After saving the webhook, Pabbly Connect will be ready to receive data whenever a new coupon is created in WooCommerce.
4. Capturing Webhook Response in Pabbly Connect
Now that the webhook is set up, return to Pabbly Connect and click on the ‘Capture Webhook Response’ button. This step allows you to test if the integration is functioning correctly.
Create a dummy coupon in WooCommerce by going to ‘Marketing’ and selecting ‘Add Coupon’. Fill in the coupon details, such as coupon code and discount type, then publish it.
Once the coupon is created, go back to Pabbly Connect and check if the webhook response has captured the coupon data. If successful, the data will appear, confirming that the integration is operational.
5. Creating an Abyssale Banner from WooCommerce Coupons
Next, it’s time to create a banner in Abyssale using the captured coupon data. In Pabbly Connect, click on the plus button to add an action step. Select ‘Abyssale’ as the app for this action.
Choose the action event as ‘Generate Banner from Another Banner’. Connect your Abyssale account by entering the API key from your Abyssale account settings. Map the coupon data to the appropriate fields in Abyssale, such as banner ID and discount percentage.
After filling in all required fields, click on ‘Save and Send Test Request’. If successful, a new banner will be created in Abyssale, confirming the integration between WooCommerce and Abyssale through Pabbly Connect.
Integrating WooCommerce and Abyssale using Pabbly Connect allows you to automate the creation of banners from WooCommerce coupons effortlessly. By following the steps outlined, you can streamline your marketing efforts effectively.
