Learn how to integrate Wix with Airtable using Pabbly Connect. This detailed tutorial provides step-by-step instructions for creating contacts in Wix from Airtable records. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating Wix with Airtable, you need to access Pabbly Connect. First, sign in to your Pabbly account and click on the ‘Access Now’ button to reach the dashboard.
Once on the dashboard, locate the blue button labeled ‘Create Workflow’. Click on it to begin setting up your integration. This is where you will define the automation process between Airtable and Wix using Pabbly Connect.
After clicking ‘Create Workflow’, you will need to name your workflow. For this tutorial, we can name it ‘Create Contact in Wix from Airtable Record’. Once named, click ‘Create’ to proceed.
  • Select ‘Airtable’ as the trigger application.
  • Choose ‘New Record’ as the trigger event.
  • Connect your Airtable account by entering the required token.
With this setup, every time a new record is created in Airtable, it will trigger the workflow in Pabbly Connect to create a corresponding contact in Wix.
3. Setting Up Airtable for Integration
To set up Airtable, create a base called ‘Team Members’ where you will add the details of each team member. Ensure to include a field for ‘Created Time’ to track when records are added.
Once you have your Airtable base ready, switch back to Pabbly Connect and refresh your connection. Select the ‘Team Members’ base and choose the appropriate trigger field for the record creation time.
4. Connecting to Wix through Pabbly Connect
After setting up Airtable, the next step is to connect to Wix. In Pabbly Connect, select ‘Wix’ as the action application and choose ‘Create Contact’ as the action event.
  • Enter your Wix App ID and Secret ID to connect.
  • Map the necessary fields like First Name, Last Name, Email, and Phone Number.
  • Click ‘Save and Send Test Request’ to finalize the setup.
This connection ensures that every new record in Airtable automatically creates a contact in Wix, utilizing the powerful features of Pabbly Connect.
5. Testing the Integration
Once the integration is set up, it’s crucial to test it. Go back to your Airtable base and add a new record with the required details. After saving, return to Pabbly Connect and send a test request.
If everything is configured correctly, you should see a confirmation that a contact has been created in Wix. Refresh your Wix account to verify that the new contact appears with all the details you provided.
This tutorial demonstrated how to integrate Wix with Airtable using Pabbly Connect. By following the steps outlined, you can automate the process of creating contacts in Wix from Airtable records efficiently. Enjoy seamless automation and improved workflow!
