Learn how to integrate Wix forms with Telegram for automatic notifications using Pabbly Connect. This guide provides detailed steps for seamless automation. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To begin integrating Wix with Telegram, you need to access Pabbly Connect. Start by visiting the Pabbly Connect dashboard, where you can sign in if you are an existing user or sign up if you are new. Signing up is quick and provides you with 100 free tasks.
Once you are logged in, locate the ‘Create Workflow’ button on the right side of the dashboard. Click on it to initiate the process of setting up your integration. You will be prompted to name your workflow, which can be something descriptive like ‘Send Telegram Message for Wix Form Submission’.
2. Setting Up the Trigger in Wix Using Pabbly Connect
In this section, we will set up the trigger for our integration using Pabbly Connect. The trigger application will be Wix, specifically using the Wix forms. Select ‘Wix’ as your trigger application and choose the event ‘New Form Submission’.
- Select Wix as the trigger application.
- Copy the generated webhook URL provided by Pabbly Connect.
Next, log into your Wix account and navigate to the ‘Automations’ section in your site’s dashboard. Click on ‘New Automation’ and name it accordingly. Set the trigger to be the specific form you want to integrate, and then select the action to ‘Send via Webhook’. Paste the webhook URL you copied earlier into the appropriate field and activate the automation.
3. Testing the Integration with Pabbly Connect
After setting up the trigger, it’s time to test the integration using Pabbly Connect. Go back to your Wix form and submit a test entry. This will allow Pabbly Connect to capture the form submission data.
Ensure that you fill in all required fields in your Wix form, such as first name, last name, email address, and any other relevant information. Once submitted, return to Pabbly Connect and check for the webhook response to confirm that the data was received successfully.
- Submit a test entry in your Wix form.
- Return to Pabbly Connect to verify the received data.
- Ensure all fields are captured correctly in the webhook response.
Once you confirm that Pabbly Connect has captured the data, you can proceed to set up the action that will send the Telegram message.
4. Configuring the Action to Send Messages via Telegram
The next step is to configure the action application, which will be Telegram, through Pabbly Connect. Select Telegram as the action application and choose the action event ‘Send Text Message’. You will need to connect your Telegram bot to Pabbly Connect.
To do this, you must create a new bot in Telegram using the BotFather. Once created, copy the token provided and paste it into Pabbly Connect to establish the connection. After successfully connecting, you need to specify the chat ID where the messages will be sent.
Select Telegram as the action application. Choose ‘Send Text Message’ as the action event. Connect your Telegram bot using the token from BotFather. Input the chat ID where you want to send messages.
Once all details are filled, you can map the fields from the Wix form submission to the message content in Telegram. This ensures that every time a new lead is submitted, the relevant details are sent to your team automatically.
5. Finalizing the Integration and Sending Test Messages
Now that you have configured both the trigger and action using Pabbly Connect, it’s time to finalize the integration. Click on ‘Save’ in Pabbly Connect to ensure all settings are stored. You can then test the entire workflow by submitting another entry in your Wix form.
If everything is set up correctly, you should receive a message in your designated Telegram chat shortly after submitting the form. This confirms that your integration between Wix and Telegram via Pabbly Connect is successful.
Click ‘Save’ in Pabbly Connect to finalize the integration. Submit a new entry in your Wix form to test. Check Telegram for the notification message.
Once you confirm the message has been received, your integration is complete, and you can automate notifications for all future Wix form submissions using Pabbly Connect.
Integrating Wix forms with Telegram using Pabbly Connect allows for seamless notifications on new leads. This guide provided step-by-step instructions to set up the integration efficiently. Automate your workflow today with Pabbly Connect to enhance communication and responsiveness.
