Learn how to automate WhatsApp messaging for IndiaMART leads using Pabbly Connect. Follow this detailed tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start utilizing Pabbly Connect for integrating WhatsApp with IndiaMART, first access the platform by entering the URL in your browser. Once on the homepage, you’ll see options to sign in or sign up.
If you are a new user, click on the ‘Sign Up for Free’ button. This allows you to create an account in just a couple of minutes, receiving 100 free tasks monthly to explore the platform. Existing users can simply log in by clicking ‘Sign In’.
After signing into Pabbly Connect, you will be directed to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ option, and a dialog box will prompt you to name your workflow.
- Name your workflow as ‘Send WhatsApp Message to IndiaMART Leads’.
- Select a folder to save your workflow, preferably under ‘Automations for Lead Management’.
After naming and selecting the folder, click on ‘Create’. You will now see two main windows: Trigger and Action. These are essential for setting up your automation.
In this step, you will define the trigger and action for your workflow using Pabbly Connect. For the trigger application, select IndiaMART and set the trigger event to ‘New Lead’. This ensures that every time a new lead is received, the workflow will initiate.
Next, you will need to establish a connection between IndiaMART and Pabbly Connect. Copy the webhook URL provided, which will act as a bridge to transfer data from IndiaMART to Pabbly Connect.
- Go to your IndiaMART account, navigate to Lead Manager, and select ‘Import/Export Leads’.
- Under the Push API section, deactivate any existing webhook and paste the copied URL into the Webhook Listener URL field.
After saving these details, your connection is established, and you can proceed to test the integration by submitting a dummy lead inquiry.
4. Sending WhatsApp Message to Leads
Once the connection is set, the next objective is to send a WhatsApp message to the leads captured via Pabbly Connect. For this, set the action application to AI CC and select ‘Send Template Message’ as the action event.
To create the connection, choose ‘Add New Connection’ and input your API key from your AI CC account. After saving, you can start configuring the message template that will be sent to the leads.
Enter the campaign name, e.g., ‘New IndiaMART Leads’. Map the mobile number and name of the lead from the previous response captured by Pabbly Connect.
Once all details are filled, click on ‘Save and Send Test Request’. This action will send the WhatsApp message to the lead, confirming that the integration is successful.
5. Conclusion and Benefits of Using Pabbly Connect
In conclusion, using Pabbly Connect to automate WhatsApp messaging for leads from IndiaMART is a straightforward process. By following the steps outlined, you can seamlessly connect these applications without any coding knowledge.
This integration not only saves time but also enhances communication with potential clients, ensuring that no lead goes unnoticed. Automating your lead responses can significantly improve your business efficiency.
With Pabbly Connect, you can explore numerous integrations and automate various tasks, making it an invaluable tool for your business.
