Learn how to integrate WhatsApp with Elementor using Pabbly Connect for seamless communication with new leads. Follow our detailed tutorial for step-by-step instructions. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start integrating WhatsApp with Elementor using Pabbly Connect, first access the Pabbly Connect dashboard. If you are a new user, sign up for an account, which takes less than two minutes. You’ll receive 100 free tasks to explore the application.
Existing users can simply sign in. Once on the dashboard, look for the ‘Create Workflow’ tab on the right-hand side. Click this tab to begin the integration process.
In this section, we will create a workflow that sends WhatsApp messages on Elementor form submissions. After clicking ‘Create Workflow’, a dialog box appears where you can name your workflow. For this example, name it something relevant, such as ‘WhatsApp Message on Elementor Form Submission.’ Click ‘Create’ to proceed. using Pabbly Connect
- Name your workflow appropriately to reflect its purpose.
- Select the trigger application, which will be Elementor.
- Choose the trigger event as ‘New Form Submission’.
After setting the trigger, you will need to define the action application. In this case, the action application is WhatsApp by AI Sensi, and the action event will be to send a template message. This setup will ensure that every time a new lead submits a form, they receive a welcome message via WhatsApp.
3. Setting Up Elementor for Pabbly Connect
Now that the workflow is created, it’s time to set up Elementor to work with Pabbly Connect. Navigate to your Elementor account and select the form you want to use. For this tutorial, we will edit the contact form.
In the form settings, find the ‘Actions After Submit’ section. Click on the plus icon to add a new action, and select ‘Webhook’. You will need to paste the webhook URL provided by Pabbly Connect. This URL acts as a bridge between Elementor and Pabbly Connect, allowing the data to flow seamlessly.
- Edit the contact form in Elementor.
- Add ‘Webhook’ as an action after submission.
- Paste the webhook URL from Pabbly Connect.
After pasting the URL, click ‘Update’ to save the changes. Now, when a user submits this form, the data will be sent to Pabbly Connect, triggering the WhatsApp message.
With the setup complete, it’s time to test the integration. Go back to your Elementor form and fill it out with test data. For example, input a first name, last name, email address, and contact number, then click submit.
Once the form is submitted, return to Pabbly Connect. You should see the response from the form submission, including all the data fields. This confirms that the integration is working correctly, and you can now proceed to set up the action to send the WhatsApp message.
Fill out the Elementor form with test data. Submit the form and check the response in Pabbly Connect. Ensure all data fields are captured correctly.
If you receive the expected data, you can proceed to the next step of sending the WhatsApp message to the new lead.
5. Sending WhatsApp Messages via Pabbly Connect
The final step is to set up the action in Pabbly Connect to send a WhatsApp message. Click on the WhatsApp by AI Sensi action and connect your account. You’ll need to enter the API key from your AI Sensi account to establish this connection.
Once connected, fill in the required fields for the WhatsApp message. This includes selecting the template you created in your AI Sensi account and mapping the necessary variables like the user’s name, email, and contact number. This mapping ensures that each message is personalized for every new lead.
Connect your WhatsApp account using the API key. Select the message template from your AI Sensi account. Map the user’s information for personalization.
Finally, click ‘Save and Send Test Request’ to ensure everything is set up correctly. If successful, the new lead will receive a WhatsApp message welcoming them onboard. This confirms that your integration is fully functional!
Integrating WhatsApp with Elementor using Pabbly Connect allows for seamless communication with new leads through automated messages. Follow the steps outlined in this tutorial to enhance your lead engagement and streamline your processes.
