Learn how to automate subscriber creation in AWeber from Webflow form submissions using Pabbly Connect. Step-by-step tutorial for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To begin automating subscriber creation in AWeber from Webflow form submissions, access Pabbly Connect. Start by signing in or signing up for a free account on the Pabbly website. This platform enables seamless integration between Webflow and AWeber without coding.
Once logged in, navigate to your dashboard. Here, you will find various tools, but focus on Pabbly Connect for this integration. Click on the ‘Create Workflow’ button to initiate the setup process.
After clicking ‘Create Workflow’, you will need to name your workflow. For this integration, name it something like ‘Create AWeber Subscriber on Webflow Form Submission’. Choose the folder where you want to save it, such as ‘Automations’. using Pabbly Connect
  • Select the folder for organization.
Once you have named your workflow, click ‘Create’. This will open the main workflow window where you will set the trigger and action. The trigger indicates the event that starts the workflow, while the action is what happens as a result. Here, select Webflow as the trigger application.
3. Setting Up the Trigger with Webflow
In the workflow window, search for Webflow and select ‘Webflow V2’ as your trigger application. Next, choose the trigger event as ‘Form Submitted’. This setting ensures that the workflow will activate whenever a form is submitted on your Webflow site.
Click on ‘Connect’ to set up the connection. You will have the option to select an existing connection or create a new one. If you are creating a new connection, follow the prompts to obtain your API token from your Webflow account. This is crucial for Pabbly Connect to access your Webflow data.
4. Configuring AWeber Action in Pabbly Connect
After successfully setting up the trigger, it’s time to configure the action. Search for AWeber in the action application section and select it. Choose the action event as ‘Add or Update Subscriber’. This allows you to create a new subscriber or update an existing one based on the form submission.
Click ‘Connect’ and grant the necessary permissions for Pabbly Connect to manage your AWeber account. You will need to provide your Account ID and List ID for the AWeber integration. This information is essential for mapping the data correctly.
  • Select ‘Add or Update Subscriber’ as the action event.
  • Provide necessary permissions for AWeber.
  • Enter your Account ID and List ID.
Once connected, you can map the fields from the Webflow form submission to the AWeber subscriber fields. This mapping ensures that the subscriber’s information is accurately transferred every time a form is submitted.
5. Testing Your Integration
With everything set up, it’s time to test your integration. Perform a test submission on your Webflow form. Fill in the required fields and submit the form. Pabbly Connect will capture this submission and process it according to your workflow.
Check your AWeber account to confirm that the new subscriber has been created. You should see the details populated as per the form submission. This confirms that your integration is working correctly and that Pabbly Connect is successfully linking Webflow with AWeber.
In summary, this integration allows you to automate the process of adding subscribers to AWeber from Webflow forms, enhancing your marketing efforts without manual intervention.
In this tutorial, we explored how to use Pabbly Connect to automate subscriber creation in AWeber from Webflow form submissions. By following these steps, you can streamline your workflow and enhance your email marketing efforts efficiently.
