Learn how to automate user enrollment in Ry using Webflow submissions with Pabbly Connect. Follow our detailed tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Accessing Pabbly Connect to Set Up Integrations
To start integrating Webflow and Ry, you need to access Pabbly Connect. Begin by visiting the Pabbly Connect homepage by typing the URL in your browser.
Once there, you will see options to sign in or sign up for free. If you are a new user, click on the ‘Sign up for free’ button to create your account. Existing users can simply log in to their accounts.
After logging into Pabbly Connect, navigate to the dashboard where you can see all your workflows. To create a new workflow, click on the ‘Create Workflow’ button.
- Provide a name for your workflow, such as ‘Enroll Ry User on Webflow Form Submission’.
- Select a folder to organize your workflows.
Now, you will see a blank workflow with two important sections: Trigger and Action. The trigger will initiate the workflow when a new form submission occurs in Webflow.
3. Setting Up Webflow as the Trigger in Pabbly Connect
In this step, you will configure Webflow as the trigger application in Pabbly Connect. Select Webflow from the trigger application options and choose the trigger event as ‘New Form Submission’.
Upon selection, you will receive a webhook URL. This URL needs to be copied and integrated into your Webflow account to establish a connection.
- Go to your Webflow account and locate the form you want to connect.
- Navigate to the settings of the form and find the Apps and Integration section.
- Add a new webhook and paste the URL you copied from Pabbly Connect.
Once the webhook is set up, publish the changes in Webflow. This will complete the trigger setup for your integration.
4. Connecting Ry as the Action in Pabbly Connect
Now that the trigger is set, it’s time to configure Ry as the action application in Pabbly Connect. Select Ry from the action application options and choose ‘Import User’ as the action event.
You will need to connect your Ry account by providing an API token. To obtain this token, go to your Ry account, navigate to the Integrations section, and enable the Pabbly integration to retrieve your API key.
Copy the API key from your Ry account. Paste the API key into Pabbly Connect to establish the connection. Map the fields such as full name, email address, and phone number from the Webflow submission.
After mapping the necessary fields, click on ‘Save and Send Test Request’. If successful, the user will be added to your Ry account.
5. Testing the Integration for Success
With everything set up, it’s crucial to test your integration in Pabbly Connect. Go back to your Webflow form and submit a test entry to see if the integration works as intended.
Once the form is submitted, return to Pabbly Connect to check if the response was captured. If the data appears correctly, this means your integration is functioning successfully.
Check the user management section in Ry to confirm the new user is added. Repeat the process with different test entries to ensure reliability.
After confirming the successful enrollment of users, your integration is complete. Every time a form is submitted in Webflow, a new user will be automatically enrolled in Ry.
In this tutorial, we explored how to use Pabbly Connect to automate user enrollment in Ry through Webflow form submissions. This integration streamlines the process, saving time and effort for online educators.
