Learn how to seamlessly integrate Webflow and Bravo using Pabbly Connect. Follow our detailed tutorial for step-by-step instructions. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To begin the integration process using Pabbly Connect, first, navigate to the Pabbly website. Type in ‘Pabbly.com/connect’ in your browser. This will take you to the Pabbly Connect dashboard where you can manage your workflows.
Once on the Pabbly Connect page, you need to sign in to your account. If you’re new, you can sign up for free, which provides 100 tasks monthly. After signing in, you will see your dashboard displaying all your workflows. Click on the ‘Pabbly Connect’ option to proceed with the integration.
In this section, we will create a new workflow in Pabbly Connect to link Webflow and Bravo. Start by clicking on the ‘Create Workflow’ button. You will be prompted to enter a name for your workflow. For example, name it ‘Create Bravo Contact from Webflow Form Submission’.
- Select the appropriate folder for your workflow.
- Click on ‘Create’ to finalize the workflow setup.
After creating the workflow, you will see two boxes labeled ‘Trigger’ and ‘Action’. The trigger application is Webflow, and the trigger event will be ‘New Form Submission’. This means that whenever a form is submitted on your Webflow site, it will trigger the workflow.
3. Connecting Webflow to Pabbly Connect
To connect Webflow with Pabbly Connect, you will need a webhook URL provided by Pabbly Connect. This URL acts as a bridge between your Webflow account and Pabbly Connect. Copy the webhook URL from the trigger setup.
- Log into your Webflow account and navigate to the project settings.
- Go to the ‘Integrations’ tab and find the ‘Webhook’ section.
- Click on ‘Add Webhook’, select ‘Form Submission’ as the trigger type, and paste the copied webhook URL.
After adding the webhook, perform a test submission on your Webflow form. This action will allow Pabbly Connect to capture the response from Webflow, confirming that the integration is successful.
4. Setting Up Bravo Integration in Pabbly Connect
Now, let’s set up Bravo as the action application in Pabbly Connect. Select Bravo and choose the action event as ‘Create or Update Contact’. Click on ‘Connect’ to establish the connection with Bravo.
If you do not have an existing connection, you will need to create a new one. Enter your domain and the API key from your Bravo account. This key is necessary for Pabbly Connect to communicate securely with Bravo.
Access your Bravo account and navigate to the SMTP and API page to generate a new API key. Copy the API key and domain and paste them into the Pabbly Connect setup.
With the connection established, you can now map the fields from the Webflow response to the Bravo contact fields, ensuring that all necessary details are captured.
5. Testing the Integration and Confirmation
After mapping the fields in Pabbly Connect, it’s time to test the integration. Click on ‘Save and Send Test Request’. This action will send the mapped data to Bravo, creating a new contact.
Once the test is complete, check your Bravo account to confirm that the contact was created successfully. Navigate to the contacts section and verify that the details match what was submitted through the Webflow form.
To ensure everything works as expected, perform additional test submissions on your Webflow form. Each submission should result in a new contact being created in Bravo, confirming that the integration via Pabbly Connect is functioning correctly.
In this tutorial, we explored how to integrate Webflow and Bravo using Pabbly Connect. By following these detailed steps, you can automate the process of creating contacts from form submissions effectively. This integration streamlines your workflow and enhances your email marketing capabilities.
