Learn how to add students to Uteach courses through ThriveCart payments and create ConvertKit subscribers using Pabbly Connect in this detailed step-by-step tutorial. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To start this integration process, you need to access Pabbly Connect. This platform allows you to connect various applications effortlessly. Begin by visiting the Pabbly Connect homepage where you can sign in or sign up for a new account.
Once logged in, navigate to the dashboard where you can create a new workflow. This is crucial for linking ThriveCart with Uteach and ConvertKit. Follow these steps:
- Visit the Pabbly Connect homepage.
- Sign in or create a new account.
- Access the dashboard and click on ‘Create Workflow’.
After creating your workflow, you can start setting up the necessary triggers and actions for the integration.
2. Setting Up ThriveCart Trigger in Pabbly Connect
In this step, you will set up the ThriveCart trigger in Pabbly Connect. This is essential to capture when a product is purchased. Select ThriveCart as your trigger application and choose ‘Product Purchase’ as the trigger event.
To connect ThriveCart, you will need your API token. Here’s how to find it:
- Log in to your ThriveCart account.
- Go to your profile settings and find API & Webhooks.
- Generate a new API key and copy it.
Paste this API key into Pabbly Connect to establish the connection successfully. After this, select the product you want to track, such as your PHP course.
3. Adding Students to Uteach Course via Pabbly Connect
After setting up the ThriveCart trigger, the next step is to add students to your Uteach course using Pabbly Connect. Select Uteach as the action application and choose ‘Create Student’ as the action event.
To connect Uteach, you need to provide the domain and API key. Here’s how to retrieve these details:
Log in to your Uteach account. Go to settings and select Integrations. Copy the domain and API key provided.
Once you have entered these details into Pabbly Connect, map the customer’s name and email from the ThriveCart trigger data. This ensures that the correct information is sent to Uteach.
4. Creating ConvertKit Subscriber with Pabbly Connect
The final integration step involves adding the student as a subscriber in ConvertKit using Pabbly Connect. Select ConvertKit as your action application and choose ‘Add Subscriber to Form’ as the action event.
For this step, you will need your ConvertKit API key and API secret key. Follow these steps to retrieve them:
Log in to your ConvertKit account. Go to settings and find the API section. Copy the API key and secret key.
Paste these keys into Pabbly Connect and select the form you want to add subscribers to. Map the relevant fields such as name, email, and tags to ensure the subscriber information is accurate.
5. Testing the Integration in Pabbly Connect
Now that you have set up all the steps in Pabbly Connect, it’s time to test the entire integration. Make a test purchase through your ThriveCart checkout page to see if the automation works as expected.
After completing the test purchase, check your Uteach and ConvertKit accounts to confirm that the student has been added successfully. If everything is set up correctly, you should see the new student in Uteach and a new subscriber in ConvertKit.
Here’s how to verify:
Check Uteach for the new student enrollment. Verify the subscriber list in ConvertKit.
If both actions are completed successfully, your integration is working perfectly! This automation saves you time and ensures students are added seamlessly to your courses.
In this tutorial, we explored how to integrate Uteach courses with ThriveCart payments and create ConvertKit subscribers using Pabbly Connect. By following these steps, you can automate your student enrollment process and enhance your online academy’s efficiency. This integration streamlines operations and helps you focus on delivering quality education.
