Learn how to integrate URL and John using P Connect for seamless automation. Follow our detailed tutorial for step-by-step instructions. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level. with Pabbly Connect.
1. Overview of URL and John Integration
The integration of URL and John allows for streamlined processes in online course management. This tutorial will guide you through automating user enrollment in your courses using P Connect.
By connecting these applications, you can automatically enroll users in your courses upon form submission, enhancing user experience and saving time. This integration is particularly useful for online coaching businesses that rely on seamless student registration.
2. Setting Up P Connect for URL and John
To start, you need to access P Connect. Open your browser and go to p.com/c/connect. If you don’t have an account, sign up for free to get started.
Once you’re logged in, you will see the dashboard. Here’s how to set up your workflow:
  • Click on ‘Create Workflow’.
  • Name your workflow (e.g., ‘Enroll Graphy User on Vix Form Submission’).
  • Select the folder to save your workflow.
After creating your workflow, you will be directed to the main setup window where you can define your trigger and action steps for the integration process.
3. Connecting Vix Forms as the Trigger
The first step in your workflow is to set up the trigger application, which in this case is Vix Forms. Search for Vix Forms in the trigger application options and select it. using Pabbly Connect
Next, choose the trigger event. For this integration, select ‘New Form Submission’. You will then need to connect Vix Forms with P Connect using the provided webhook URL. Copy this URL and head to your Vix account to set up the automation.
  • Go to the Automations section in Vix.
  • Create a new automation and name it.
  • Select ‘Form Submitted’ as your trigger event.
After setting this up, paste the webhook URL into the Target URL field in Vix, and activate your automation. This will allow P Connect to receive responses from Vix Forms whenever a new submission occurs.
4. Creating a New Learner in Graphy
Once the trigger is set, the next action is to create a new learner in Graphy. In P Connect, search for Graphy as your action application and select ‘Create Learner’ as the action event. using Pabbly Connect
To connect Graphy with P Connect, you will need your API Key and Merchant ID. You can retrieve these from the Integrations section of your Graphy account. After filling in the required details, map the responses from Vix Forms to the fields in Graphy.
Enter the API Key and Merchant ID in P Connect. Map the email, first name, and last name from the Vix form submission. Leave the password field blank for the student to create their own.
After saving the settings, send a test response to confirm that the learner has been created successfully in your Graphy account. You can verify this by checking the Users section in Graphy to see the newly created learner’s details.
5. Enrolling the Learner in a Course
After successfully creating the learner, the final step is to enroll them in a specific course within Graphy. Again, select Graphy as your action application and choose ‘Enroll Learner to Course’ as your action event. using Pabbly Connect
Use the email of the learner you created earlier and specify the course URL from Graphy. You can find the course URL in the Products section of your Graphy account. Copy this URL and paste it into the appropriate field in P Connect.
Once you have filled in all required details, save and send a test request. If successful, you will see a confirmation response indicating that the learner has been enrolled in the course. You can check back in Graphy to ensure the learner is now part of the course.
This tutorial has demonstrated how to integrate URL and John using P Connect for seamless automation in course enrollment. By following these steps, you can streamline your registration process and enhance user experience effectively.
