Learn how to integrate Typeform with Go High Level and Airtable using Pabbly Connect. Follow this step-by-step guide for seamless automation. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To start integrating Typeform with Go High Level and Airtable, you first need to access Pabbly Connect. Open your browser and go to the Pabbly Connect website.
Once on the site, sign in to your Pabbly account. If you are a new user, click on ‘Sign up for free’ to create an account and receive 100 free tasks monthly. After logging in, navigate to the Pabbly Connect dashboard to create your workflow.
In the Pabbly Connect dashboard, you can create a new workflow for your integration. Click on the ‘Create Workflow’ button and name your workflow, for example, ‘Create Go High Level Contact on Typeform Submission’. using Pabbly Connect
- Click on the plus icon to create a new folder if needed.
- Select the folder to save your workflow.
- Once created, you will see trigger and action boxes.
Set the trigger application to Typeform, with the event as ‘New Entry’. This means that every time a form is submitted, the workflow will be triggered. Click on ‘Connect’ to establish a connection with Typeform.
3. Setting Up Typeform in Pabbly Connect
After connecting Typeform, you need to select the form you will use for submissions. Choose the ‘New Contact Form’ from your Typeform account and click on ‘Save and Send Test Request’. using Pabbly Connect
To test the integration, you must submit a sample form entry. Open the Typeform link, fill in the fields, and submit it. This step is crucial as it allows Pabbly Connect to capture the response from Typeform.
4. Integrating Go High Level with Pabbly Connect
In this step, you will set up Go High Level as your action application. Select ‘Lead Connector V2’ and choose the action event as ‘Create Contact’. Click on ‘Connect’ to link your Go High Level account. using Pabbly Connect
- Map the fields from Typeform to Go High Level.
- Ensure that first name, last name, email, and phone number are correctly mapped.
Once the mapping is complete, click on ‘Save and Send Test Request’ to verify that the contact is created successfully in Go High Level.
5. Adding Records to Airtable via Pabbly Connect
The final step involves integrating Airtable to store the contact details. Set Airtable as your action application and select the action event as ‘Create Record’. Connect your Airtable account. using Pabbly Connect
Choose the base you want to use, such as ‘Typeform Data’, and map the fields again. Ensure that all relevant details from Typeform are included in the Airtable record. Click on ‘Save and Send Test Request’ to finalize the integration.
In this tutorial, we explored how to automate the integration of Typeform, Go High Level, and Airtable using Pabbly Connect. By following these steps, you can streamline your data collection and management processes effectively.
