Learn how to automate the creation of Flowlu contacts from Typeform submissions using Pabbly Connect in this detailed tutorial. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To create a Flowlu contact on Typeform submission, you’ll first need to access Pabbly Connect. This platform allows seamless integration between various applications, including Typeform and Flowlu.
Start by visiting the Pabbly Connect website. If you’re a new user, sign up for a free account, which provides 100 free tasks every month. Existing users can simply log in to their account to access the dashboard.
After logging into Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard.
A dialog box will appear, prompting you to name your workflow. Enter ‘Create Flowlu Contact on Typeform Submission’ and select a folder for your workflow. For this example, choose the ‘Typeform Automations’ folder.
- Click the ‘Create’ button to finalize your workflow.
- You will now see two sections: Trigger and Action.
The trigger is what initiates the workflow, and the action is what happens as a result. In this case, the trigger will be a new submission in Typeform.
3. Setting Up the Trigger with Typeform
For the trigger application, select Pabbly Connect as Typeform. Choose the trigger event as ‘New Entry’ to capture new submissions.
Click on the ‘Connect’ button, which will prompt you to add a new connection or select an existing one. Choose to connect with Typeform by clicking on ‘Connect with Typeform’ and authorize the connection by clicking the ‘Accept’ button.
- Select the specific form you want to use for the trigger.
- Click on ‘Save and Send Test Request’ to check the connection.
Perform a test submission on your Typeform to ensure that the response is captured correctly in Pabbly Connect. You should see the details of the submission in the trigger section.
4. Setting Up the Action to Create a Contact in Flowlu
Now that the trigger is set, it’s time to set up the action step. For the action application, select Pabbly Connect as Flowlu and choose the action event as ‘Create CRM Account’.
Click on the ‘Connect’ button, where you will need to enter your Flowlu account URL and API key. You can obtain the API key from your Flowlu account settings under API settings.
Map the fields from the Typeform submission to the corresponding fields in Flowlu. Make sure to fill in all required fields, such as first name, last name, email, and address.
After mapping the data, click on the ‘Save and Send Test Request’ button to create a new contact in Flowlu. Check your Flowlu account to confirm that the contact has been created successfully.
5. Conclusion: Automating Your Workflow with Pabbly Connect
In this tutorial, we’ve demonstrated how to automate the process of creating a Flowlu contact from Typeform submissions using Pabbly Connect. This integration saves time and ensures that all lead data is captured seamlessly.
By following these steps, you can easily set up similar automations between other applications as well. Utilizing Pabbly Connect enhances your workflow efficiency and allows for better management of your leads.
For any further queries or assistance regarding Pabbly Connect, feel free to reach out through the support channels available.
