Learn how to integrate Trigger with Michael Caris Using Pabbly Connect for seamless automation. Follow our step-by-step tutorial to automate your Google Form submissions. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes. with Pabbly Connect.
Setting Up Trigger Integration with Google Forms
To begin with the integration using P Connect Now, we need to set up the trigger for Google Forms. This step is crucial as it allows us to capture new form submissions effectively. First, open P Connect Now and sign in to your account. If you don’t have an account, you can sign up for free and get started.
Once logged in, click on the ‘Create Workflow’ button. In the pop-up window, name your workflow as ‘Enroll Tag Mango User on Google Form Submission’. Select the folder where you want to save your workflow, and then click ‘Create’. This will take you to the main workflow window where you can set up the trigger and action.
Configuring Google Forms Trigger in P Connect Now
In this section, we will configure the Google Forms trigger in P Connect Now. Start by searching for the Google Forms application in the trigger section. Select it and then choose the trigger event, which should be ‘New Response Received’. This event will activate the workflow whenever a new form submission occurs.
Next, you need to connect Google Forms with P Connect Now using the provided WB URL. Copy this URL and navigate to your Google Form. Here, you will connect the form responses to P Connect Now by using the P Rec VB extension. If you haven’t installed it yet, go to ‘Add-ons’ in Google Sheets, search for ‘P Rec VB’, and install it.
- Open your Google Sheet linked to the Google Form.
- Go to Extensions > P Rec VB > Initial Setup.
- Paste the copied WB URL into the setup window.
- Set the trigger column to the last data entry column (Column E).
After configuring the initial setup, make sure to enable the ‘Send on Event’ option in the P Rec VB settings. This ensures that every new form submission automatically sends the data to P Connect Now.
Creating User Enrollment in Tag Mango
The next step involves creating a new user enrollment in Tag Mango using the data received from Google Forms. Start by selecting Tag Mango as your action application in P Connect Now. Choose the action event ‘Create User’ to initiate the enrollment process.
To connect Tag Mango with P Connect Now, you will need your API key. Log into your Tag Mango account, navigate to the dashboard, and find the option for Automation. Under Platform Integration, copy the API key provided. Return to P Connect Now and paste this API key into the connection setup.
- Map the user details from Google Forms to the corresponding fields in Tag Mango.
- Ensure to format the phone number correctly by using the Text Formatter tool.
- Select the appropriate course ID and coupon code for the enrollment.
Once all details are mapped correctly, click on ‘Save’ to finalize the user enrollment setup. You should see a confirmation response indicating that the user has been successfully enrolled.
Testing the Integration
Now that you have set up the integration, it’s time to test it. Go back to your Google Form and submit a new entry. For this example, enter the name ‘Michael Caris’, email ‘[email protected]’, and a random phone number. After submitting the form, check your Google Sheet to confirm that a new row has been added.
Next, navigate back to P Connect Now to see if the new form submission has triggered the workflow. You should see the details of Michael Caris reflected in the response section. This means that the data has been successfully transferred from Google Forms to P Connect Now.
Verify that the user data appears correctly in your Tag Mango account. Check for any errors in the mapping process. Repeat the process with a different user, such as ‘John Doe’.
After confirming that everything works as expected, your integration is complete and ready for use. Now, every new Google Form submission will automatically enroll users in Tag Mango.
In this tutorial, we covered how to integrate Trigger with Michael Caris Using Pabbly Connect effectively. By automating the process of enrolling users from Google Forms to Tag Mango, you can save time and streamline your workflows. This integration allows for seamless data transfer and enhances your online coaching experience.
