Learn how to integrate Trigger and Automation Using Pabbly Connect for seamless Facebook lead ads management and email marketing. Follow our detailed tutorial now! Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background. with Pabbly Connect.
1. Setting Up Trigger for Facebook Lead Ads
To begin with the integration, the first step is to set up the trigger using Trigger from Facebook Lead Ads. This allows you to automatically capture leads from your Facebook campaigns. You need to connect your Facebook account to the Automation platform.
Once you have access to the Automation dashboard, you will create a new workflow. Select Facebook Lead Ads as your trigger application and choose the ‘New Lead Instant’ event. This will ensure that every new lead captured will initiate the workflow.
2. Connecting Facebook Lead Ads to Automation
Next, you need to link your Facebook Lead Ads account to Automation. To do this, click on ‘Connect’ and follow the prompts to grant access. Ensure you select the correct Facebook page, which in this case is named Prime Properties.
  • Choose your Facebook page for the ads.
  • Select the lead generation form you wish to use.
  • Make sure your lead form is live before testing.
After connecting, you will need to generate a sample submission to test the connection. This can be done using the Facebook Lead Ads Debug Tool to ensure everything is functioning correctly.
3. Creating a Subscriber in PAB Email Marketing
After setting up the trigger, the next step is to create a subscriber in PAB Email Marketing. This is where the information from the lead will be sent. You will need to select the action application as PAB Email Marketing and the action event as ‘Add Subscriber’.
To connect PAB Email Marketing with Automation, you will need an API token. Log in to your PAB Email Marketing account, navigate to Integrations, and generate a new API token. Copy this token and paste it back into the Automation platform to establish the connection.
4. Mapping Data from Facebook to PAB Email Marketing
Once the connection is established, you need to map the data from Facebook Lead Ads to PAB Email Marketing. This involves specifying which fields from the lead form correspond to the subscriber details in your email marketing list.
For instance, map the first name, last name, and email address of the lead. This ensures that every new lead will automatically create a subscriber with the correct details. After mapping, click on ‘Save and Send Test’ to verify that the subscriber is added correctly.
  • Ensure all required fields are filled in the mapping process.
  • Test the mapping by generating a new lead submission.
  • Check your PAB Email Marketing list for the new subscriber.
After confirming that the subscriber has been created successfully, you can now automate your email marketing efforts using PAB Email Marketing.
5. Finalizing the Automation Workflow
After successfully creating the subscriber, you can finalize the automation workflow. This step is crucial as it ensures that every new lead from Facebook Lead Ads is automatically added as a subscriber in PAB Email Marketing.
To complete the workflow, review all settings and ensure that the trigger and actions are correctly set up. This will allow for seamless integration and automation of your email marketing efforts. With this setup, you can easily manage your leads and send them tailored updates.
By following these steps, you have successfully integrated Trigger with Automation Using Pabbly Connect, enabling you to automate your email marketing efforts effectively. This integration allows you to capture leads from Facebook and manage them efficiently in your email marketing campaigns.
