Learn how to integrate Trigger with Automation, Slack, and Instam Mojo for seamless payment notifications in this detailed tutorial. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation. with Pabbly Connect.
1. Setting Up Trigger for Failed Payments
In this section, we will focus on setting up the Trigger for failed payments using Instam Mojo. The first step is to create a connection using Pabbly Connect to automate notifications for failed payments.
To do this, navigate to Pabbly Connect and create a new workflow. Name your workflow appropriately, such as ‘Notify Team on Slack for Failed Instam Mojo Payment’. After naming it, click on the ‘Create’ button to proceed to the trigger setup.
2. Configuring Action to Notify on Slack
After setting up the Trigger, the next step involves configuring the action to send notifications to Slack. For this, you will select Slack as your action application in Pabbly Connect.
- Select ‘Send Channel Message’ as the action event.
- Connect your Slack account by providing the necessary permissions.
- Choose the specific channel where notifications will be sent.
Once you have set up the action, you will need to create a notification message that includes details such as customer name, phone number, email, product name, and payment amount. This ensures your team is promptly informed about failed payments.
3. Connecting Instam Mojo with Pabbly Connect
To connect Instam Mojo with Pabbly Connect, you will need to generate a webhook URL. This URL acts as a bridge between the two applications. Copy the webhook URL from Pabbly Connect and navigate to your Instam Mojo account. using Pabbly Connect
Inside Instam Mojo, go to the page settings for the product you wish to monitor. Here, you can paste the copied webhook URL into the webhook settings. Make sure to select the option for failed payments to ensure the correct data is sent.
4. Testing the Automation Workflow
After setting up the integration, it is crucial to test the workflow to ensure it functions as intended. Create a test payment using the PHP product page in Instam Mojo, intentionally entering incorrect payment details to trigger a failure. using Pabbly Connect
Once the payment fails, check Pabbly Connect to see if the webhook response was received. If successful, a notification should be sent to your selected Slack channel, confirming that the automation is working correctly.
5. Conclusion: Streamlining Notifications with Automation
In this tutorial, we explored how to integrate Trigger with Automation to notify your team about failed payments via Slack. By following the steps outlined, you can ensure timely communication and quick resolution of payment issues.
This integration not only enhances operational efficiency but also improves customer service by allowing your team to respond promptly to payment failures. Implement this automation today to streamline your payment notifications!
