Learn how to automate TradingView alerts to Telegram using Pabbly Connect in this detailed tutorial. Follow the exact steps to set up your integration successfully.
To begin integrating TradingView alerts with Telegram, you need to access Pabbly Connect. Start by opening your browser and searching for the Pabbly Connect website. Here, you will find options to either sign in or sign up for a free account.
After signing in, navigate to the ‘All Apps’ page and click on ‘Access Now’ under Pabbly Connect. This will take you to the Pabbly Connect dashboard, where you can create a new automation workflow for your TradingView alerts.
2. Creating the Automation Workflow in Pabbly Connect
Once you are on the Pabbly Connect dashboard, click on the ‘Create Workflow’ button. You will be prompted to name your workflow. For example, name it ‘TradingView to Telegram’ and select the appropriate folder in your Pabbly account.
- Click on ‘Create’ to open your automation workflow.
- You will see two windows: a trigger window and an action window.
- Begin with the trigger window to connect TradingView.
In the trigger window, search for ‘TradingView’ and select it. Choose the trigger event as ‘New Alert’. This setup ensures that whenever a new alert is created in TradingView, it will be captured by Pabbly Connect.
3. Setting Up TradingView Alerts
To set up alerts in TradingView, open the chart for the stock or index you want to monitor, such as the Nifty50 index. Click on the ‘Create Alert’ button to configure your alert settings.
- Select the condition for your alert, like ‘Crossing’ for price.
- Set the alert price and choose whether it triggers ‘Only Once’ or ‘Every Time’.
- Enter the alert message that will be sent to Telegram.
In the notification section, paste the webhook URL provided by Pabbly Connect into the appropriate field. This URL connects TradingView to your Pabbly Connect workflow, allowing alerts to be sent automatically.
4. Sending Alerts to Telegram Using Pabbly Connect
After setting up the TradingView alerts, return to your Pabbly Connect workflow. In the action window, search for ‘Telegram’ and select the Telegram Bot app. Choose the action event as ‘Send a Text Message’.
Create a Telegram bot using BotFather and obtain your bot’s API token. Paste the API token into Pabbly Connect to establish the connection. Map the alert message from TradingView to the Telegram message field.
Once the connection is established, you can test the integration by creating a new alert in TradingView. The alert message should be sent to your specified Telegram channel, demonstrating how Pabbly Connect successfully automates this process.
To ensure everything is working correctly, create a new alert in TradingView with a different price than before. Set the alert message and ensure the webhook URL is correctly configured.
After creating the alert, check your Telegram channel. You should see the alert message posted, confirming that Pabbly Connect has successfully transmitted the information from TradingView to Telegram.
This successful integration not only automates the alert process but also enhances communication within your trading community. You can further customize the alerts or add other applications using Pabbly Connect for enhanced functionality.
In this tutorial, we explored how to use Pabbly Connect to automate the process of sending TradingView alerts to Telegram. By following the exact steps outlined, you can streamline your trading notifications effectively.
