Learn how to integrate ThriveCart with Uteach using Pabbly Connect. Follow this detailed tutorial for seamless automation and efficient student enrollment. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start integrating ThriveCart with Uteach, you need to access Pabbly Connect. First, open your browser and search for Pabbly Connect. You will find options to sign in or sign up for free. If you are a new user, click on the ‘Sign up for free’ button to create an account.
Once you create your account, you will receive 100 free tasks to explore the features of Pabbly Connect. If you are an existing user, simply click on ‘Sign in’. After signing in, navigate to the ‘All Apps’ section and select Pabbly Connect to access the dashboard.
In this section, you will create a new workflow to automate the student enrollment process. Click on the ‘Create Workflow’ button located in the top right corner of your Pabbly Connect dashboard. A dialog box will prompt you to name your workflow. Enter a suitable name, such as ‘Create Student and Enroll in Uteach for ThriveCart Purchase’.
  • Click on the ‘Create’ button.
  • You will see two windows: Trigger and Action.
  • Select ‘ThriveCart’ as the Trigger application.
Set the trigger event to ‘Product Purchase’. This means whenever a new product is purchased in ThriveCart, it will initiate the workflow in Pabbly Connect.
3. Connecting ThriveCart to Pabbly Connect
After selecting ThriveCart as your trigger, you need to connect your ThriveCart account with Pabbly Connect. Click on ‘Connect’, then select ‘Add New Connection’. You will be prompted to enter an API token from your ThriveCart account.
To find the API token, log in to your ThriveCart account, go to the settings section, and click on ‘API and Webhooks’. Here, create a new API key by clicking on the ‘Create API Key’ button. Once created, copy the API key and paste it into Pabbly Connect. Click ‘Save’ to establish the connection.
4. Testing the Integration with a Purchase
With the connection established, it’s time to test the integration. Select the product you want to track for purchases in ThriveCart. For this example, choose the ‘Advanced PHP Course’. Click on ‘Save and Send Test Request’ in Pabbly Connect to wait for a response.
Now, make a test purchase in ThriveCart for the Advanced PHP Course. Enter dummy customer information, including name and email, and complete the payment using a test card. Once the payment is processed, return to Pabbly Connect to check if the response with customer details has been received successfully.
5. Enrolling the Student in Uteach
After receiving the response from ThriveCart, the next step is to enroll the student in Uteach. In Pabbly Connect, set the action application to Uteach and select the action event as ‘Find User’. Connect your Uteach account by entering the required API key and domain, which you can find in your Uteach account settings.
Once connected, map the email from the ThriveCart response to find the user in Uteach. If the user exists, you can directly enroll them in the desired course. If not, create a new user in Uteach and then enroll them. This automation ensures that every student who purchases a course is seamlessly added to your Uteach account.
This tutorial demonstrates how to use Pabbly Connect to automate the integration between ThriveCart and Uteach for efficient student enrollment. By following the steps outlined, you can streamline your processes and ensure that every purchase results in automatic student addition, enhancing your workflow significantly.
