Learn how to integrate ThriveCart with System.io using Pabbly Connect to automate contact creation and tagging seamlessly. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start integrating ThriveCart with System.io, first, access Pabbly Connect by visiting the official website. If you are a new user, click on ‘Sign up for free’ to create your account. Existing users can simply sign in to access their dashboard.
Once logged in, you will see various Pabbly applications. Click on Pabbly Connect, which is the automation tool we will use for this integration. This platform allows seamless connections between different applications without the need for coding.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button. You will be prompted to name your workflow and select a folder for organization. For example, name it ‘ThriveCart to System.io Integration’ and save it in the ‘Automations’ folder.
  • Select the folder for saving the workflow.
Upon creating the workflow, you will be directed to the workflow window. This is where you will set up the trigger and action for your integration. The trigger will be a new purchase in ThriveCart, and the action will be creating a contact in System.io.
3. Setting Up the Trigger for ThriveCart
In the workflow window, select ThriveCart as your trigger application. You will then choose the trigger event as ‘Product Purchase’. This means that the workflow will trigger whenever a new product is purchased through ThriveCart.
Next, click on ‘Connect’ to add a new connection. You will need an API key from your ThriveCart account to establish this connection. This key can be found in the API/Webhook section of your ThriveCart settings.
  • Select ‘Add New Connection’ and paste the API key.
  • Choose the product for which you want to set up the trigger.
  • Click ‘Save and Send Test Request’ to check if the connection is successful.
After completing these steps, Pabbly Connect will be ready to capture new purchase data from ThriveCart, allowing you to automate contact creation in System.io.
4. Action Step: Creating a Contact in System.io
Now that the trigger is set up, it’s time to define the action step in Pabbly Connect. Choose System.io as your action application and select ‘Create Contact’ as the action event. This action will create a new contact in System.io whenever a purchase is made in ThriveCart.
Click on ‘Connect’ and add a new connection by providing the API key from your System.io account. Navigate to the profile settings in System.io to create and retrieve this API key.
Enter the API key to connect System.io with Pabbly Connect. Map the required fields such as email, first name, and last name from the ThriveCart trigger data. Click ‘Save and Send Test Request’ to create a test contact.
With these steps, Pabbly Connect will automatically create a contact in System.io based on the purchase details from ThriveCart, streamlining your marketing efforts.
5. Adding Tags to Contacts in System.io
The final step in this integration process is to add tags to the newly created contacts in System.io. In Pabbly Connect, add another action step by selecting System.io and choosing ‘Add Tag to Contact’ as the action event.
Use the mapping feature to dynamically assign the contact ID from the previous step. Specify the tag name you wish to assign, such as ‘Java BYOD’ for contacts purchasing the Java course.
Select the existing connection for System.io. Map the contact ID and specify the tag to be added. Click ‘Save and Send Test Request’ to finalize the tagging process.
By following these steps, Pabbly Connect ensures that every new contact created in System.io from ThriveCart purchases is tagged appropriately, enhancing your marketing segmentation.
This tutorial demonstrated how to integrate ThriveCart with System.io using Pabbly Connect. By automating contact creation and tagging, you can enhance your marketing strategies and save valuable time on manual tasks.
