Learn how to integrate ThriveCart and Airtable using Pabbly Connect for seamless payment tracking automation. Follow this detailed tutorial for step-by-step guidance. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To begin the integration process using Pabbly Connect, first, log in to your account. If you don’t have an account, you can create a free one in just a few minutes. After logging in, you will be directed to the Pabbly Connect dashboard.
Once on the dashboard, click on the blue button labeled ‘Create Workflow’. You will need to provide a name for your workflow, such as ‘Add ThriveCart Payment Details to Airtable Automatically’. After naming your workflow, click on the ‘Create’ button to proceed.
2. Setting Up the Trigger Event in Pabbly Connect
In this section, you will set up the trigger event in Pabbly Connect. The trigger is what initiates the automation process. For this integration, select ThriveCart as your application and choose the trigger event as ‘New Product Purchase’.
- Select ThriveCart as the application.
- Choose the trigger event: New Product Purchase.
- Click on ‘Connect’ and then ‘Add New Connection’.
- Enter your API key from ThriveCart.
After entering the API key, click on ‘Save’. This will connect ThriveCart to Pabbly Connect. You can now test the connection by making a dummy payment on ThriveCart to ensure everything is set up correctly.
3. Testing the Trigger in Pabbly Connect
Once you have set up the trigger, it’s time to test it. Make a dummy payment in ThriveCart to simulate a transaction. After the payment is processed, return to Pabbly Connect to see if the payment details are captured.
- Go to the checkout page of a product in ThriveCart.
- Complete the payment using test card details.
- Check if the payment details are received in Pabbly Connect.
After making the dummy payment, you should see all relevant payment details, such as product name, price, and customer information, appear in Pabbly Connect. This confirms that the trigger is functioning correctly.
4. Setting Up the Action Event in Pabbly Connect
Now that the trigger is working, you need to set up the action event. The action is what happens after the trigger fires. For this integration, select Airtable as your application and choose ‘Create Record’ as the action event. using Pabbly Connect
Click on ‘Connect’ and then ‘Add New Connection’. You will need to enter your Airtable API key. Once connected, select the base and table where you want the payment details to be stored. This is where all the payment information will be sent.
5. Mapping Data in Pabbly Connect
The final step is to map the data from ThriveCart to Airtable. This means you need to specify which payment details go into which fields in your Airtable table. Click on each field in the Airtable action to map the corresponding data from ThriveCart.
Map fields like product name, price, customer name, and email. Ensure all necessary fields are mapped accurately. Click on ‘Save’ and test the action to confirm it works.
Once the data is mapped and saved, you can test the entire workflow. When a new payment is made in ThriveCart, the details will automatically be added to your Airtable table via Pabbly Connect. This automation allows for seamless tracking of payment information.
By following this tutorial, you have successfully integrated ThriveCart and Airtable using Pabbly Connect. This integration automates the process of tracking payment details, saving you time and effort. With Pabbly Connect, you can streamline your workflow and focus on growing your business.
