Learn how to recover abandoned carts using Pabbly Connect to integrate Thrive Cart with SendFox. Follow our detailed tutorial for seamless automation. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To recover abandoned carts with Thrive Cart and SendFox, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in to your account.
If you are a new user, you can sign up for free and get 100 tasks monthly. Existing users should click on the ‘Sign In’ button to access their dashboard. After signing in, navigate to the Pabbly Connect application to begin the integration process.
Once you are in Pabbly Connect, click on the ‘Create Workflow’ button. This will prompt you to name your workflow. Enter a descriptive name, such as ‘Recover Abandoned Thrive Carts with SendFox,’ and select the appropriate folder for saving your workflow.
- Click on ‘Create’ to proceed to the workflow window.
- In this window, you will set up the trigger and action.
- Triggers are the commands that initiate your workflow.
In the workflow window, select ‘Thrive Cart’ as your trigger application. The trigger event should be set to ‘Cart Abandoned’ to capture when a customer leaves their cart without completing the purchase.
3. Connecting Thrive Cart to Pabbly Connect
After selecting Thrive Cart, you will need to connect your Thrive Cart account to Pabbly Connect. Click on ‘Connect’ and choose to add a new connection. You will be prompted to enter your API key, which can be found in the API settings of your Thrive Cart account.
To retrieve the API key, navigate to the API and Webhook section in your Thrive Cart settings. Create a new API key, name it appropriately (e.g., ‘Abandoned Cart’), and copy it. Paste this key into the Pabbly Connect workflow and click on ‘Save’ to establish the connection.
4. Setting Up SendFox Integration in Pabbly Connect
With Thrive Cart connected, the next step is to set up SendFox as your action application in Pabbly Connect. Search for and select ‘SendFox’ as your action application. Choose the action event as ‘Add Contacts to List’ to automatically add new contacts from abandoned carts.
- Click on ‘Connect’ and select to add a new connection.
- Retrieve your SendFox personal access token from your SendFox account settings.
- Paste the token into Pabbly Connect and click ‘Save’ to connect.
After successfully connecting SendFox, select the contact list (e.g., ‘Abandoned Cards’) where you want to add the new contacts. Map the necessary fields such as first name, last name, and email from the Thrive Cart trigger response to ensure the data is correctly transferred.
5. Testing the Integration
After setting up the workflow, it’s essential to test the integration to ensure everything is functioning correctly. To do this, perform a test submission by creating a dummy entry in your Thrive Cart and leaving the cart abandoned.
Once the test is complete, return to Pabbly Connect and check for the response. If successful, you will see the new contact added to your SendFox account, confirming that your workflow is working as intended.
With this setup, you can effectively recover abandoned carts and convert potential customers into paying clients through targeted email marketing campaigns.
In this tutorial, we explored how to integrate Thrive Cart and SendFox using Pabbly Connect. By following these steps, you can automate the recovery of abandoned carts and enhance your email marketing efforts effectively.
