Learn how to integrate Thrive Cart with ConvertKit using Pabbly Connect to recover abandoned carts and create targeted email marketing campaigns. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start integrating Thrive Cart with ConvertKit, you will need to access Pabbly Connect. Open your browser and navigate to the Pabbly website. Here, you will find options to sign in or sign up for a free account.
If you are a new user, click on ‘Sign up for free’ to create an account. Existing users should click on ‘Sign in’ to access their dashboard. Once logged in, locate the Pabbly Connect application and click on ‘Access Now’ to proceed with the integration setup.
After accessing Pabbly Connect, you will need to create a new workflow. Click on the ‘Create Workflow’ button, and you will be prompted to name your workflow. Enter a descriptive name such as ‘Recover Abandoned Carts with Thrive Cart and ConvertKit’.
Next, select the folder where you want to save this workflow. After naming it, click on ‘Create’ to open the workflow window. This window is crucial as it will allow you to set up triggers and actions.
- Name your workflow appropriately for easy identification.
- Select the folder for organizing your workflows.
- Click on ‘Create’ to finalize the workflow setup.
Now that your workflow is created, you can set up the trigger for the abandoned cart event.
In this step, you will define the trigger for your workflow using Pabbly Connect. Select ‘Thrive Cart’ as your trigger application. This is essential to capture when a cart is abandoned.
For the trigger event, choose ‘Cart Abandon’. Click on ‘Connect’ to link your Thrive Cart account. If you have previously connected it, you can select the existing connection. Otherwise, click on ‘Add New Connection’ and enter the required API key obtained from your Thrive Cart account settings.
- Select ‘Thrive Cart’ as the trigger application.
- Choose ‘Cart Abandon’ as the trigger event.
- Connect your Thrive Cart account using the API key.
After successfully connecting, you will need to select the product for which you want to set up this automation.
4. Testing the Integration in Pabbly Connect
Once the trigger is set, it’s time to test the integration using Pabbly Connect. You will need to perform a test submission in Thrive Cart. Open your Thrive Cart account and navigate to the course you wish to test.
Copy the URL for the checkout page and open it in a new tab. Fill in the required fields such as first name, last name, email, and address. After entering the details, abandon the cart by closing the page. This action will trigger the workflow in Pabbly Connect after a short wait.
Perform a test submission on your Thrive Cart checkout page. Fill in all necessary fields and abandon the cart. Wait for the webhook response to trigger in Pabbly Connect.
After a brief waiting period, check back in Pabbly Connect to see if the response is successfully captured.
5. Finalizing the Action in Pabbly Connect
Now that the trigger is working, it’s time to set the action in Pabbly Connect. For this, select ‘ConvertKit’ as your action application. You will then choose the action event as ‘Add Subscriber to Sequence’.
Click on ‘Connect’ and provide the necessary API key and secret from your ConvertKit account. After successfully connecting, select the sequence you want to add the subscriber to. Map the email and other relevant details from the trigger response to ensure the subscriber is created correctly.
Select ‘ConvertKit’ as the action application. Choose ‘Add Subscriber to Sequence’ as the action event. Map the email and details from the Thrive Cart trigger response.
Once everything is mapped correctly, save the action and check your ConvertKit account to confirm that the subscriber has been successfully added.
In this tutorial, we explored how to use Pabbly Connect to integrate Thrive Cart with ConvertKit effectively. By following the steps outlined, you can automate the process of recovering abandoned carts and create targeted email marketing campaigns. This integration streamlines your workflow and enhances customer engagement.
