Learn how to automate form submissions from Swipe Pages to MailerLite and Airtable using Pabbly Connect. Step-by-step tutorial for seamless integration. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To start automating the process of integrating Swipe Pages with MailerLite and Airtable, you will first need to set up Pabbly Connect. Begin by accessing the Pabbly Connect dashboard, which can be done by signing up for a free account. This process is quick and allows you to create workflows seamlessly.
Once you’re on the dashboard, click on the ‘Create Workflow’ button. Name your workflow, for example, ‘Swipe Pages to MailerLite and Airtable’. This naming helps in identifying the workflow later. After naming, click on the ‘Create’ button to proceed.
2. Triggering Automation with Swipe Pages
The next step involves setting up the trigger for your workflow using Pabbly Connect. In the trigger window, search for and select ‘Swipe Pages’ as the application. Choose ‘New Form Submission’ as the trigger event. This allows Pabbly Connect to listen for new submissions made on your Swipe Pages form.
  • Select ‘Swipe Pages’ in the application search.
After copying the webhook URL, go to your Swipe Pages account to integrate this URL into your form settings. Navigate to the form settings, click on ‘Integration’, and then select ‘Webhooks’. Here, paste the webhook URL, ensuring the webhook type is set to ‘Form Submission’. This setup allows Pabbly Connect to receive form responses automatically.
3. Adding Subscribers to MailerLite
With the trigger set, it’s time to add the form submitter as a subscriber in MailerLite using Pabbly Connect. In the action window, search for ‘MailerLite’ and select it. Choose ‘Create or Update Subscriber’ as the action event. This will ensure that any new form submission will either create a new subscriber or update an existing one.
To connect your MailerLite account, you will need to provide the API token from your MailerLite account. Navigate to the Integrations section in MailerLite, generate a new API token, and copy it. Paste this token into Pabbly Connect to establish the connection.
  • Select the email address field and map it to the email response from Swipe Pages.
  • Set the subscriber status to ‘Active’.
  • Choose the appropriate group for the subscriber.
After mapping the fields correctly, click on ‘Save and Send Test Request’ to verify that the subscriber is added correctly to MailerLite. You should see a confirmation response indicating success.
4. Adding Form Responses to Airtable
The final step involves adding the form submissions as records in Airtable using Pabbly Connect. In the action step, search for ‘Airtable’ and select it. Choose ‘Create Record’ as the action event. This allows you to store the data received from Swipe Pages into your Airtable database.
To connect your Airtable account, you will need to provide the API token. Go to your Airtable account, create a new personal access token, and copy it. Paste this token into Pabbly Connect to establish the connection.
Select the base where you want to store the data. Choose the specific table to add the form responses. Map all relevant fields like first name, last name, email, and mobile number.
After mapping the fields, click on ‘Save and Send Test Request’. You should receive a positive response confirming that the data has been added to Airtable.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the integration of form submissions from Swipe Pages to MailerLite and Airtable. By following these steps, you can efficiently manage your subscriber list and store form responses without manual input. This automation saves time and enhances productivity.
