Learn how to integrate Stripe with Slack using Pabbly Connect. Follow our detailed tutorial for setting up automation workflows for specific payment links. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
Setting Up Stripe Webhook Using Pabbly Connect
To set up a webhook in Stripe, start by accessing Pabbly Connect. This platform will facilitate the integration between Stripe and Slack. Begin by creating a new workflow in Pabbly Connect and selecting Stripe as your trigger application.
Next, select the trigger event as ‘Checkout Completed’. This event will allow Pabbly Connect to capture payment details when a checkout is successfully completed. Once selected, Pabbly Connect will provide you with a webhook URL that needs to be added to your Stripe account.
Adding the Webhook in Stripe
After obtaining the webhook URL from Pabbly Connect, navigate to your Stripe account. In the test mode, go to the ‘Developers’ section and select ‘Webhooks’. Click on ‘Add Endpoint’ to set up the webhook.
In the endpoint setup, paste the webhook URL from Pabbly Connect. Make sure to select the event type that corresponds to the trigger you set up earlier. This ensures that Stripe sends payment details to Pabbly Connect whenever a checkout is completed.
- Select your Stripe account for the data source.
- Choose the specific event type for your automation.
- Click ‘Create Endpoint’ to finalize the setup.
With the webhook now added, Stripe will send payment responses to the webhook URL whenever a checkout is completed. This integration is essential for enabling automation workflows in Pabbly Connect.
Capturing Payment Response in Pabbly Connect
Once the webhook is set up, return to Pabbly Connect. The platform will show that it is waiting for a response from Stripe. To test this, make a dummy payment using the payment link you set up in Stripe.
Upon completing the payment, Pabbly Connect will capture the response from Stripe. You will see various details including payment status, customer information, and the unique payment link. This data is crucial for the next steps in your automation workflow.
- Verify the payment method and status in the captured response.
- Identify the unique payment link from the response.
- Ensure all customer details are captured accurately.
With this data, you can proceed to set up conditions for your automation workflow in Pabbly Connect, ensuring that actions are taken only for specific products.
Setting Up Filter Condition in Pabbly Connect
In this step, you will set up a filter condition in Pabbly Connect to ensure that the automation workflow only continues for specific payment links. This is essential for targeting notifications accurately.
To do this, add a filter step in your workflow. Select the data object for the payment link from the Stripe response. Set the filter to check if the payment link equals the specific link you want to track.
For instance, if you want to set up notifications for a personal finance consultation payment link, copy that unique payment link and paste it into the filter condition. This ensures that only payments made through this link will trigger subsequent actions in your workflow.
Sending Notifications to Slack Using Pabbly Connect
Finally, integrate Slack into your workflow using Pabbly Connect. After setting up the filter condition, add an action step to send a message to a designated Slack channel whenever a payment is received.
Choose Slack as your action application and set the action event to ‘Send Channel Message’. Connect your Slack account and select the channel where you want to receive notifications. Customize the message to include relevant payment details such as customer name, email, and payment amount.
After mapping the necessary fields from the Stripe response to your Slack message, test the integration by making another payment through the specified payment link. If set up correctly, you will receive a notification in your Slack channel confirming the payment.
In this tutorial, we’ve demonstrated how to use Pabbly Connect to integrate Stripe with Slack effectively. By setting up webhooks, capturing payment responses, and configuring filter conditions, you can automate notifications for specific products seamlessly.
