Learn how to instantly add Sendicate subscribers from new Shopify customers using Pabbly Connect. Follow our detailed tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To begin integrating Shopify with Sendicate, you first need to access Pabbly Connect. This platform acts as the central hub for connecting your applications. Start by signing into your Pabbly Connect account.
Once logged in, navigate to the dashboard where you can create a new workflow. This is where you will set up the integration between Shopify and Sendicate, ensuring that new customers from Shopify are automatically added as subscribers in Sendicate.
In this step, you will create a workflow that connects Shopify and Sendicate through Pabbly Connect. Click on the ‘Create Workflow’ button and give your workflow a name that reflects its purpose, such as ‘Shopify to Sendicate Integration’.
Next, select Shopify as the trigger application. You will need to choose the trigger event, which in this case is ‘New Customer’. This event will initiate the workflow whenever a new customer is created in your Shopify store.
  • Click on the ‘Connect’ button to link your Shopify account.
  • Authorize Pabbly Connect to access your Shopify data.
  • Test the trigger to ensure it works correctly.
After successfully setting up the trigger, you can move on to the next step of the integration process.
3. Adding Sendicate Subscriber Action
Now that you have set up the trigger in Pabbly Connect, it’s time to add the action for Sendicate. Choose Sendicate as the action application in your workflow. This will allow you to add new subscribers based on the data received from Shopify.
Select the action event as ‘Add Subscriber’. You will then need to connect your Sendicate account by clicking on the ‘Connect’ button. Authorize Pabbly Connect to interact with your Sendicate account, allowing it to add subscribers automatically.
  • Map the fields from Shopify to Sendicate, such as email, first name, and last name.
  • Test the action to ensure that a subscriber is added in Sendicate when a new customer is created in Shopify.
Once everything is set up and tested, you’re ready to activate your workflow. This ensures that all new customers from Shopify are automatically added as subscribers in Sendicate.
4. Finalizing the Integration in Pabbly Connect
After testing your workflow, it’s crucial to finalize the integration in Pabbly Connect. Make sure to save your workflow and turn it on. This step is essential to ensure that the integration runs continuously and automatically adds new subscribers.
You can also monitor the workflow’s performance from the Pabbly Connect dashboard. Here, you can view logs of the actions taken and check for any errors that may occur during the integration process.
To enhance your integration, consider setting up additional actions or notifications based on specific triggers. This can help you manage your subscribers more effectively and keep your customer engagement at its peak.
5. Conclusion: Seamless Integration with Pabbly Connect
In conclusion, using Pabbly Connect to integrate Shopify with Sendicate allows for a seamless process where new customers are automatically added as subscribers. This integration not only saves time but also enhances your marketing efforts by keeping your subscriber list up to date.
By following the steps outlined in this tutorial, you can easily set up this integration and ensure that your business operates smoothly. Start utilizing Pabbly Connect today to automate your workflows and improve your customer engagement.
