Integrating Shopify with Mailchimp Using Pabbly Connect
1. Introduction to Integration
Integrating Shopify with Mailchimp is essential for effective marketing. This integration allows seamless data transfer between the two platforms.
Using Pabbly Connect, you can automate customer data transfers. This setup is straightforward and requires only a few steps.
2. Setting Up the Workflow
Begin by creating an account on Pabbly Connect. Log in and navigate to the dashboard to initiate your workflow.
Select the option to create a new workflow and name it “Shopify to Mailchimp.” This name helps identify your integration easily.
3. Connecting Shopify and Mailchimp
Use the webhook feature in Shopify to send customer data to Pabbly Connect. This involves setting a new customer trigger in Shopify.
Next, link Mailchimp by adding a new member from the captured data. Enter the required details like first name and email.
This guide outlines how to integrate Shopify with Mailchimp using Pabbly Connect, ensuring smooth customer data transfer and efficient marketing efforts.
