Learn how to integrate Shopify and WooCommerce using Pabbly Connect. This detailed tutorial covers all steps for syncing products seamlessly. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To start integrating Shopify and WooCommerce, you first need to access Pabbly Connect. Sign in to your existing account or create a new one to get started. If you are a new user, you can sign up for free and receive 100 tasks for free, which is a great way to explore the platform.
Once logged in, navigate to the dashboard by clicking on the Pabbly Connect option. This dashboard is where you will create your workflow to sync products between Shopify and WooCommerce seamlessly.
In Pabbly Connect, creating a workflow is essential for automating the product sync process. Click on the Create Workflow button located in the top right corner of the dashboard. You will be prompted to name your workflow; for this integration, name it ‘Sync Shopify Product with WooCommerce’.
- Select the folder where you want to save this workflow.
- Click on Create to proceed.
After creating the workflow, you will see the trigger and action setup window. This is where you will define what event will trigger the action in WooCommerce.
3. Setting Up Shopify as the Trigger Application
The next step in Pabbly Connect is to set up Shopify as the trigger application. In the trigger window, search for and select Shopify. You will then need to select the trigger event, which is ‘New Product’.
Once you select the trigger event, a webhook URL will be generated. This URL will be used to connect Shopify with Pabbly Connect. Copy this URL, as you will need it to set up the webhook in your Shopify account.
4. Connecting Shopify to Pabbly Connect
To connect Shopify with Pabbly Connect, go to your Shopify account and navigate to Settings. From there, select Notifications and find the Webhooks section. Click on the Create Webhook button.
- Choose the event type as ‘Product Creation’.
- Set the format to JSON.
- Paste the webhook URL copied from Pabbly Connect.
After saving the webhook, you can test the connection by creating a new product in Shopify. This will send the product data to Pabbly Connect, allowing you to see the captured response.
5. Setting Up WooCommerce as the Action Application
After confirming that Shopify is successfully connected to Pabbly Connect, proceed to set up WooCommerce as the action application. In the action window, search for WooCommerce and select it. Choose the action event as ‘Create Product’.
Next, you will need to establish a connection between WooCommerce and Pabbly Connect. You can either use an existing connection or create a new one by providing the consumer key and secret from your WooCommerce settings.
Once connected, map the required fields such as product name, SKU, price, and image URL from the Shopify response. This ensures that whenever a new product is created in Shopify, the same details are automatically transferred to WooCommerce, maintaining consistency across both platforms.
This tutorial demonstrates how to use Pabbly Connect to integrate Shopify and WooCommerce effectively. By following these steps, you can automate the product synchronization process, ensuring that your inventory remains updated across both platforms. This integration not only saves time but also enhances operational efficiency.
