Learn how to integrate Shopify with Moosend using Pabbly Connect to verify email addresses instantly and automate your email marketing process. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start integrating Shopify with Moosend, we will use Pabbly Connect. First, access the Pabbly website by entering Pabbly.com in your browser. Once on the site, hover over the product section and click on Connect to sign in.
After signing in, you will see the dashboard of Pabbly Connect. Here, you can create a new workflow. Click on the button to create a new workflow and name it ‘Shopify to Moosend’. This sets the stage for our integration process.
2. Setting Up Shopify Trigger in Pabbly Connect
In this step, we will set up Shopify as the trigger application in Pabbly Connect. Select Shopify from the app list and choose the trigger event as ‘New Order’. This event will activate the workflow whenever a new order is created in Shopify.
- Select Shopify as the app.
- Choose ‘New Order’ as the trigger event.
- Copy the Webhook URL provided by Pabbly Connect.
Next, you will paste this Webhook URL into your Shopify account to establish the connection. Go to Shopify settings, click on Notifications, then scroll to the Webhooks section and create a new webhook. Select ‘Order Creation’ as the event and paste the copied URL.
3. Capturing Webhook Response from Shopify
After setting up the Webhook in Shopify, we need to capture the webhook response in Pabbly Connect. This is done by creating a new order in Shopify. Once the order is placed, Pabbly Connect will receive the data automatically.
For this demonstration, create a test order in your Shopify store. Input a valid email and ensure the order is processed. After creating the order, check Pabbly Connect to see if the response from Shopify has been captured successfully. You will see details such as order ID and email address.
4. Verifying Email with Email List Verify
Now that we have captured the webhook response, the next step is to verify the email address using Email List Verify through Pabbly Connect. Add Email List Verify as the next step in your workflow.
- Select Email List Verify as the app.
- Choose ‘Single Email Verify’ as the action event.
- Paste the API key from your Email List Verify account.
Input the email address from the Shopify order into the Email List Verify step. This will check if the email is valid. If the email is verified, we can proceed to add the subscriber to Moosend. Make sure to save your workflow.
5. Adding Subscriber to Moosend
Finally, we will use Pabbly Connect to add the verified email as a subscriber in Moosend. Select Moosend as the app and choose ‘Add New Subscriber’ as the action event. This will allow us to add the verified email to our mailing list.
Input the required fields such as mailing list name and subscriber details. Ensure that you map the email and name from the previous steps. Save your workflow and test it by creating a new order in Shopify.
After testing, check your Moosend account to confirm that the new subscriber has been added successfully. This integration ensures that only verified emails from Shopify orders are added to your Moosend mailing list.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Shopify with Moosend effectively. By verifying email addresses, you can ensure your email marketing efforts are targeted and efficient. This integration streamlines your workflow, making it easier to manage subscribers.
