Learn how to integrate Razorpay with Shopify using Pabbly Connect for real-time order creation. Follow this detailed tutorial for seamless automation. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To begin integrating Razorpay with Shopify, access Pabbly Connect. This platform serves as a powerful tool for creating automated workflows between applications. Start by signing up for a free account on the Pabbly Connect website and logging in to your dashboard.
Once logged in, you will find the option to create a new workflow. This is where you will set up the connection between Razorpay and Shopify. Ensure you have your Razorpay and Shopify credentials ready for a smooth integration process.
Creating a workflow in Pabbly Connect is straightforward. Click on the ‘Create Workflow’ button. You will be prompted to name your workflow, which helps in identifying it later. Choose a name that reflects the integration, such as ‘Razorpay Shopify Integration’.
  • Click on the ‘Create’ button after naming your workflow.
  • Select Razorpay as the trigger application.
  • Choose ‘New Order’ as the trigger event.
After setting up the trigger, you will need to connect your Razorpay account to Pabbly Connect. This involves entering your API key and secret, which can be found in your Razorpay account settings. This step is crucial for enabling communication between the two applications.
3. Setting Up Shopify Integration
After configuring Razorpay, the next step is to set up Shopify in Pabbly Connect. Click on the ‘Add Action Step’ button. Select Shopify as the action application and choose the ‘Create Order’ action event. This action will create a new order in Shopify whenever a new order is placed in Razorpay.
  • Connect your Shopify account by entering your store URL and API credentials.
  • Map the required fields from Razorpay to Shopify, such as customer details and order amount.
Once the mapping is complete, test the integration to ensure that new orders in Razorpay are successfully creating orders in Shopify. This testing phase is essential to confirm that all data is transmitted correctly between the two platforms using Pabbly Connect.
4. Sending Email Notifications via Gmail
In addition to creating orders in Shopify, you can set up email notifications using Gmail through Pabbly Connect. After setting up the Shopify action, click on the ‘Add Action Step’ again. Select Gmail as the action application and choose the ‘Send Email’ action event.
Connect your Gmail account and fill in the required fields, such as the recipient’s email address, subject, and body of the email. This email can notify customers about their order confirmation.
Make sure to customize the email content by including dynamic fields from the Razorpay order, such as order ID and amount. This ensures that the email contains relevant information for the customer. Testing this step will confirm that emails are sent correctly after an order is created in Shopify.
After completing all the steps, it’s time to finalize the integration using Pabbly Connect. Click on the ‘Save’ button to store your workflow settings. Ensure that all connections are active and correctly configured.
To test the entire workflow, create a test order in Razorpay and check if it generates a corresponding order in Shopify and sends an email notification via Gmail. This step verifies that your integration works seamlessly and efficiently.
Once confirmed, you can start using this integration for real-time order processing. This automation saves time and improves customer experience by ensuring timely notifications and order management.
In this tutorial, you learned how to integrate Razorpay with Shopify using Pabbly Connect. This integration automates the order creation process and enhances customer communication through email notifications. By following these steps, you can streamline your e-commerce operations effectively.
