Learn how to integrate Razorpay with Go High Level using Pabbly Connect for seamless automation. Follow this detailed tutorial for step-by-step instructions. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start the integration process, access Pabbly Connect by visiting the official website. Once there, you can either sign in if you already have an account or sign up for free if you are a new user. Signing up provides you with 100 tasks free every month, making it an excellent choice for beginners.
After signing in, navigate to the dashboard where you will find various Pabbly applications. For this tutorial, we will focus on Pabbly Connect, which enables the connection between Razorpay and Go High Level. Click on ‘Access Now’ to begin creating your workflow.
Once you are in Pabbly Connect, click on the ‘Create Workflow’ button to initiate your automation setup. You will be prompted to name your workflow and select a folder to save it in. For this integration, name your workflow as ‘Create Go High Level Contact on Razorpay Payment’ and choose the appropriate folder.
- Click on the ‘Create’ button to open the workflow window.
- This window allows you to set triggers and actions for your automation.
In this window, select Razorpay as your trigger application. This means that whenever a new payment is captured in Razorpay, it will trigger the workflow to create a new contact in Go High Level. Select ‘Payment Captured’ as the trigger event, and copy the webhook URL provided by Pabbly Connect.
3. Setting Up the Webhook in Razorpay
To link Razorpay with Pabbly Connect, you need to set up a webhook in your Razorpay account. Log in to your Razorpay account, navigate to the ‘Developers’ section, and select ‘Webhooks’. Here, click on the ‘Add New Webhook’ button.
- Paste the webhook URL copied from Pabbly Connect.
- Select the event ‘Payment Captured’ to ensure that the webhook triggers on payment success.
- Click on ‘Create Webhook’ to finalize the setup.
After successfully creating the webhook, Razorpay will send payment details to Pabbly Connect whenever a new payment is made. This connection is crucial for automating the contact creation process in Go High Level.
4. Testing the Integration
With the webhook set up, it’s time to test the integration. You can do this by making a test payment through Razorpay. Open your Razorpay payment page and enter dummy details to complete a payment. Once the payment is successful, Razorpay will send the payment details to Pabbly Connect.
After making the test payment, return to your Pabbly Connect workflow. You should see that the webhook has captured the response from Razorpay, including the payment details you entered. This confirms that the connection is working correctly.
Now, you can proceed to the next step of your automation, which is to filter the payment amount and create a new contact in Go High Level using the captured details.
5. Creating a Contact in Go High Level
To create a contact in Go High Level, add an action step in Pabbly Connect by selecting ‘Lead Connector V2’ as the action application. Choose the action event ‘Create or Update a Contact’. This step will allow you to map the captured payment details to create a new contact.
When prompted, connect your Go High Level account to Pabbly Connect. You will need to select the sub-account where the new contact should be created. After connecting, you can map the necessary fields such as first name, last name, email, and phone number from the Razorpay payment details.
Once all required fields are mapped, click on ‘Save and Send Test Request’. If successful, you will see a confirmation that a new contact has been created in your Go High Level account. This completes the integration process, ensuring that every new payment results in a new contact being created automatically.
This tutorial showcased how to use Pabbly Connect to automate the process of creating Go High Level contacts upon receiving payments through Razorpay. By following these steps, you can streamline your customer management and enhance communication efficiency.
