Learn how to integrate Razorpay with Go High Level using Pabbly Connect for seamless automation of contact creation upon payment capture. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To begin the integration process, access Pabbly Connect by searching for ‘Pabbly Connect’ in your browser. This platform allows you to create automated workflows between different applications.
Once you reach the Pabbly Connect landing page, you will see options to sign in or sign up. If you are a new user, click on ‘Sign up for free’ to get started with 100 tasks free every month. Existing users should click on ‘Sign in’ to access their dashboard.
After signing into Pabbly Connect, you can create a new workflow by clicking on the ‘Create Workflow’ button. This is where you define the automation process.
When prompted, enter the workflow name, such as ‘Create Go High Level Contact on Razorpay Payment’. Choose a folder to save it in, like ‘Automations’, and then click on ‘Create’. This opens the workflow window where you will set up the trigger and action.
- Define the trigger application (Razorpay).
- Select the trigger event (Payment Captured).
- Copy the provided webhook URL for Razorpay.
By setting up these parameters in Pabbly Connect, you initiate the automation process that will capture payments and trigger actions accordingly.
3. Setting Up Webhooks in Razorpay
To establish a connection between Pabbly Connect and Razorpay, you need to set up webhooks. Go to your Razorpay account, navigate to the ‘Developers’ section, and select ‘Webhooks’.
Click on ‘Add New Webhook’ and paste the webhook URL you copied from Pabbly Connect. You can leave the secret field blank and specify the alert email. Choose the event ‘Payment Captured’ and click on ‘Create Webhook’. You will see a success message indicating that the webhook has been created.
- Navigate to Razorpay Developers section.
- Select Webhooks and click Add New Webhook.
- Paste the webhook URL and set the event to Payment Captured.
With the webhook set up, Pabbly Connect is now ready to receive payment notifications from Razorpay, allowing you to automate contact creation in Go High Level.
4. Testing the Integration with a Payment
To ensure the integration works, perform a test payment through Razorpay. Access the payment page for your course and fill in the necessary details, including dummy information for first name, last name, email, and phone number.
After entering the details, select the payment method (e.g., card), input card details, and submit the payment. Once the payment is successful, Razorpay will send the information to Pabbly Connect, allowing you to verify if the webhook response is captured correctly.
Fill in the payment details accurately. Submit the payment and check for successful confirmation. Verify Pabbly Connect captures the payment details.
Once verified, you can proceed to create a contact in Go High Level using the captured payment information, ensuring that your automation is functioning correctly.
5. Creating a Contact in Go High Level
After confirming that Pabbly Connect has captured the payment details, you can create a new contact in Go High Level. Add an action step in your workflow and select ‘Lead Connector V2’ as the application.
Choose the action event as ‘Create or Update a Contact’ and connect your Go High Level account. Map the fields from the Razorpay response, such as first name, last name, email, and phone number. This dynamic mapping ensures that every new payment creates a corresponding contact automatically.
Select Lead Connector V2 for creating contacts. Map the fields from Razorpay to Go High Level. Test to ensure the contact is created successfully.
With this final step, Pabbly Connect completes the automation process, allowing you to manage contacts efficiently without manual input, thus streamlining your operations.
In this tutorial, we explored how to integrate Razorpay and Go High Level using Pabbly Connect. This integration automates the contact creation process upon payment capture, enhancing efficiency in customer management.
By following the steps outlined, you can set up a seamless workflow that saves time and ensures accurate data transfer between applications. This setup not only improves communication but also allows for a more organized approach to managing customer interactions.
