Learn how to automate subscriber management in ConvertKit using Razorpay payments with Pabbly Connect in this detailed tutorial. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To integrate Razorpay with ConvertKit, you first need to access Pabbly Connect. Open your browser and navigate to the Pabbly Connect website. If you don’t have an account, click on the ‘Sign Up for Free’ button to create one. Signing up is quick and gives you access to 100 free tasks each month.
After signing in, you will be directed to the Pabbly Connect dashboard. Here, you can see various applications that Pabbly offers. Click on the ‘Create Workflow’ button to start building your integration workflow.
In the workflow creation window of Pabbly Connect, name your workflow something descriptive, like ‘Add ConvertKit Subscriber on Razorpay Payment’. Choose a folder to save your workflow for easy access later. After naming and selecting the folder, click on the ‘Create’ button.
  • Select Razorpay as the trigger application.
  • Choose ‘Order Paid’ as the trigger event.
These steps will set up Razorpay as the trigger for your workflow. This means that every time a payment is received, it will initiate the next action in your workflow.
3. Connecting Razorpay with Pabbly Connect
To connect Razorpay with Pabbly Connect, go to your Razorpay account and navigate to Account Settings. Here, find the option for Webhooks. Click on ‘Add New Webhook’ and paste the copied webhook URL from Pabbly Connect. Select the event ‘Order Paid’ as the active event to track.
After saving the webhook, return to Pabbly Connect. The platform will now wait for a response from Razorpay. To test the connection, create a new order in Razorpay and complete the payment process. This step is crucial as it allows Pabbly Connect to receive the payment details needed for the next action.
4. Setting Up ConvertKit Integration with Pabbly Connect
Once the payment is confirmed, the next step involves setting up ConvertKit in Pabbly Connect. In the action application field, select ConvertKit. The action event should be ‘Add Subscriber to a Sequence’. This action will ensure that the customer who made the payment will receive the relevant emails.
  • Connect ConvertKit by adding your API Key and API Secret.
  • Select the specific email sequence in ConvertKit where the subscriber should be added.
  • Map the customer details from Razorpay to ConvertKit fields.
This mapping is essential as it personalizes the emails sent to the subscriber. After completing these steps, you will have successfully set up the integration between Razorpay and ConvertKit using Pabbly Connect.
5. Testing the Integration
After configuring the workflow, it’s important to test the integration to ensure it works correctly. In Pabbly Connect, you can simulate a payment to see if a new subscriber is added in ConvertKit. Make a test payment using Razorpay and check your ConvertKit account for the new subscriber.
Verify that the subscriber’s details, such as name and email, are correctly reflected in ConvertKit. If everything is set up properly, you will see the subscriber added to the designated sequence. This confirms that the integration is functioning as expected.
In this tutorial, we explored how to use Pabbly Connect to integrate Razorpay with ConvertKit effectively. By automating the process of adding subscribers to email sequences based on payments, you can enhance customer engagement and streamline your marketing efforts. This integration ensures that every payment received translates into timely communication with your customers.
