Learn how to automate the addition of Razorpay payment details to Notion using Pabbly Connect. Follow our step-by-step tutorial for seamless integration. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To start integrating Razorpay with Notion, you need to access Pabbly Connect. Begin by opening your browser and navigating to the Pabbly Connect landing page. Sign in to your account using the top-right corner options.
If you’re a new user, click on ‘Sign up for free’ to create an account and receive 100 free tasks monthly. Once logged in, you will see the dashboard where you can create workflows that automate tasks between applications.
In this step, we will create a new workflow in Pabbly Connect to connect Razorpay and Notion. Click on the ‘Create Workflow’ button, and you will be prompted to name your workflow. Name it ‘Add Razorpay Payment Details to Notion’ and select the folder for saving.
- Click on ‘Create’ to initiate the workflow.
- You will see two boxes: one for the trigger and another for the action.
- Choose Razorpay as the trigger application and set the trigger event to ‘Payment Captured’.
Now, connect Razorpay with Pabbly Connect by using the webhook URL provided in your trigger setup. This URL acts as a bridge for communication between Razorpay and Pabbly Connect.
3. Setting Up the Webhook in Razorpay
To complete the integration, you need to set up a webhook in Razorpay. Navigate to your Razorpay dashboard, click on ‘Developers’, then ‘Webhooks’. Here, click on ‘Add New Webhook’.
- Paste the webhook URL from Pabbly Connect in the Webhook URL field.
- Leave the Secret and Alert Email fields blank.
- Select ‘Payment Captured’ as the active event and click ‘Create Webhook’.
Once the webhook is created, return to Pabbly Connect where it will indicate that it’s waiting for a webhook response. Now, proceed to test the integration by making a payment in Razorpay.
4. Testing the Integration with a Payment
To test the integration, go to your Razorpay payment page and fill in the necessary details to make a payment for the product. Use dummy details for testing purposes.
Ensure the product selected is Java notes and proceed with the payment. Complete the payment process to generate a webhook response.
Once the payment is successfully made, return to Pabbly Connect to verify that the payment details have been captured. You will see the response showing details such as the name, email, and phone number of the payer.
5. Adding Payment Details to Notion
Now that we have the payment details captured in Pabbly Connect, the next step is to add these details to Notion. Set up a new action in your workflow by selecting Notion as the action application and the event as ‘Create Database Item’.
Connect to your Notion account, select the database page where you want to add the payment details, and map the fields using the data received from Razorpay. Ensure to use the mapping feature to keep the data dynamic.
Finally, click on ‘Save and Send Test Request’ to send the data to Notion. Verify in your Notion database that the payment details have been added correctly, confirming that the automation is working smoothly.
This tutorial demonstrated how to integrate Razorpay payments with Notion using Pabbly Connect. By following the steps outlined, you can automate the process of adding payment details seamlessly. This integration enhances your workflow efficiency and ensures accurate record-keeping.
