Learn how to integrate Razorpay payments with Notion using Pabbly Connect in this step-by-step tutorial. Automate your payment details effortlessly! Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To start integrating Razorpay with Notion, you need to access Pabbly Connect. Begin by visiting the Pabbly Connect website by typing ‘Pabbly.com/connect’ in your browser.
Once on the site, sign in or create a new account. If you are new, you can sign up for free, which provides you with 100 free tasks monthly. After signing in, navigate to the Pabbly Connect dashboard where you can create a new workflow.
In your Pabbly Connect dashboard, click on ‘Create Workflow’ to start building your automation. You will be prompted to name the workflow, such as ‘Add New Razorpay Payment Details in Notion’.
After naming your workflow, select a folder for organization. You will now see two boxes: one for the trigger and one for the action. The trigger will be Razorpay, specifically the event ‘Payment Captured’, while the action will be Notion where the payment details will be logged.
  • Click on ‘Create’ to proceed to the trigger setup.
  • Choose Razorpay as the trigger application.
  • Set the trigger event to ‘Payment Captured’.
With the trigger set up, you will receive a webhook URL from Pabbly Connect which you will use to connect Razorpay to Pabbly.
3. Connecting Razorpay to Pabbly Connect
Next, you need to connect Razorpay to Pabbly Connect using the webhook URL. Navigate to your Razorpay dashboard, click on ‘Developers’, and then select ‘Webhooks’.
Click on ‘Add New Webhook’ and paste the webhook URL provided by Pabbly Connect into the Webhook URL field. For the event, select ‘Payment Captured’. After filling in the required fields, click ‘Create Webhook’ to save your settings.
  • Go back to Pabbly Connect and wait for the webhook response.
  • Perform a test payment in Razorpay to capture the data.
  • Check if the payment details appear in Pabbly Connect.
Once the test payment is successful, you will see the captured payment details in Pabbly Connect, confirming the connection is established.
4. Setting Up the Action in Notion
After capturing the payment details from Razorpay, it’s time to set up the action in Notion using Pabbly Connect. Choose Notion as the action application and select ‘Create Database Item’ as the action event.
Connect your Notion account to Pabbly Connect by selecting the appropriate page where you want to store the payment details. Make sure to allow access for Pabbly Connect to your Notion account.
Map the fields from Razorpay to the corresponding fields in Notion. Enter details like name, email, and phone number using the mapping feature. Click ‘Save and Send Test Request’ to verify the action.
Upon successful execution, you will see the payment details added to your Notion database, confirming that Pabbly Connect has successfully automated the process.
5. Testing the Automation for Accuracy
To ensure that your automation works perfectly, test the payment process again. Go back to Razorpay and perform another test payment for the same product.
After completing the payment, check your Notion database to confirm that the new details have been added. This step validates that the integration via Pabbly Connect is functioning correctly.
Make sure to enter different user details to see the changes. Verify that each payment reflects accurately in Notion. Repeat testing to ensure consistency in data logging.
Once confirmed, you can rely on this automation for your educational business, ensuring that every payment is recorded seamlessly through Pabbly Connect.
In this tutorial, we explored how to integrate Razorpay payments with Notion using Pabbly Connect. By following these steps, you can automate the logging of payment details efficiently. This integration streamlines your workflow and enhances productivity, allowing you to focus on your business growth.
