Learn how to instantly add Klaviyo subscribers when a Razorpay invoice is paid using Pabbly Connect. Follow our detailed tutorial for seamless integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Setting Up Pabbly Connect for Razorpay and Klaviyo Integration
To begin integrating Razorpay and Klaviyo, access Pabbly Connect. This platform allows you to automate workflows effectively. First, create an account on Pabbly Connect if you don’t have one already. It’s free and easy to sign up.
Once logged in, navigate to the ‘Create Workflow’ section. Here, you will set up a new workflow specifically for connecting Razorpay and Klaviyo. This is the first step in ensuring that your Razorpay invoices trigger actions in Klaviyo.
2. Configuring Razorpay Integration in Pabbly Connect
In this step, you will configure Razorpay within Pabbly Connect. Select Razorpay as the trigger application. This will allow you to set up a trigger event that will activate whenever an invoice is paid.
  • Choose the trigger event as ‘Invoice Paid’ from the dropdown menu.
  • Connect your Razorpay account by providing the required API keys.
  • Test the connection to ensure everything is set up correctly.
After successfully configuring the Razorpay integration, you will be prompted to map the data fields. This step is crucial as it ensures that the correct information is sent to Klaviyo when an invoice is paid.
3. Adding Klaviyo Subscriber in Pabbly Connect
Next, you’ll set up Klaviyo as the action application in Pabbly Connect. This means that once Razorpay confirms an invoice payment, it will trigger an action in Klaviyo to add a new subscriber.
Select Klaviyo from the action application list. Then, choose the action event as ‘Add Subscriber’. You will need to connect your Klaviyo account by entering the API key and other required details. This connection allows Pabbly Connect to send subscriber data directly to Klaviyo.
  • Map the necessary fields such as email address, first name, and last name from Razorpay to Klaviyo.
  • Ensure that you have the correct list selected in Klaviyo where the subscriber will be added.
Once the mapping is complete, you can test this action to confirm that the subscriber is added correctly in Klaviyo whenever an invoice is paid in Razorpay.
4. Finalizing the Integration with Pabbly Connect
After testing the integration, it’s time to finalize everything in Pabbly Connect. Review your workflow to ensure that all steps are configured correctly. This includes checking both Razorpay and Klaviyo settings.
Once satisfied, turn on the workflow. This will enable the automation to run live, meaning every time a Razorpay invoice is paid, a new subscriber will be added to Klaviyo automatically.
To monitor the integration, you can check the task history in Pabbly Connect. This feature allows you to see the logs of successful and failed tasks, helping you troubleshoot any issues that may arise.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Razorpay and Klaviyo effectively. By following these steps, you can instantly add Klaviyo subscribers when a Razorpay invoice is paid. This automation saves time and ensures your marketing lists are always up to date.
