Learn how to integrate Razor with Trigger Using Pabbly Connect to automate subscriber creation on successful payments. Follow our detailed tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation. with Pabbly Connect.
1. Integrating Razor Pay with Kit Using P Connect
The integration of Razor Pay is essential for automating subscriber creation in Kit. This process allows for seamless management of course enrollments. When a payment is successfully completed through Razor Pay, a new subscriber is automatically created in Kit.
To initiate this integration, you’ll need to use P Connect. This software simplifies the automation process without requiring coding skills. Here’s how to set it up:
2. Setting Up P Connect for Automation
To start using P Connect, open a new tab and navigate to p.com/c/connect. You will see options to sign in or sign up for free. If you are new, clicking on the ‘Sign Up for Free’ button will allow you to create an account in just a couple of minutes.
  • Sign Up for Free to get 100 free tasks each month.
  • Sign In if you already have an account.
Once signed in, access the dashboard of P Connect and create a new workflow. Click on the ‘Create Workflow’ button, name your workflow, and select the appropriate folder to save it. This will prepare you for the next steps in the integration process.
3. Setting Up the Trigger with Razor Pay
The first step in your workflow involves setting up the trigger using Razor Pay. This is critical as it dictates when the automation will occur. Search for Razor Pay as your trigger application and select it. using Pabbly Connect
Next, choose the trigger event as ‘Payment Captured’. This event will activate whenever a successful payment is made. You will then need to connect Razor Pay with P Connect using the provided webhook URL. Copy this URL as it will bridge Razor Pay and P Connect.
4. Creating a Webhook in Razor Pay
To create a webhook, log into your Razor Pay account and navigate to Account Settings. Under this section, find ‘Website and App Settings’ and select the option for Webhooks. Here, click on ‘Add New Webhook’. using Pabbly Connect
  • Paste the webhook URL you copied from P Connect.
  • Select ‘Payment Captured’ as the active event.
Once you have filled in these details, click on the ‘Create Webhook’ button. This action will link Razor Pay to P Connect, allowing for the automation of subscriber creation in Kit.
After setting up the webhook, return to P Connect. You will see that it is waiting for a webhook response. To test this, create a new successful payment through Razor Pay.
Navigate to the payment pages in Razor Pay, select a course, and fill in the payment details. Once you complete the payment, P Connect should receive a response containing all relevant customer data. This confirms that the integration is working correctly.
Finally, map the customer details to create a new subscriber in Kit using the action setup in P Connect. Select ‘Add Subscriber to a Sequence’ as your action event. Ensure that you have the API key and secret from your Kit account for a successful connection.
This tutorial detailed how to integrate Razor with Trigger Using Pabbly Connect, allowing for automated subscriber creation in Kit upon successful payments. By following these steps, you can streamline your workflow effectively.
