Learn how to integrate Razor Pay with Live Webinar using Pabbly Connect in this detailed tutorial. Automate your webinar registrations effortlessly! Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Introduction to Pabbly Connect and Its Purpose
Pabbly Connect is an automation tool that helps integrate various applications seamlessly. In this tutorial, we will use Pabbly Connect to connect Razor Pay with Live Webinar. This integration allows automatic registration of webinar participants upon receiving payments through Razor Pay.
By using Pabbly Connect, you can automate the process of adding new registrants to your webinar, saving time and reducing errors. This ensures a smooth experience for your attendees and allows you to focus on delivering your content effectively.
2. Setting Up Pabbly Connect for Integration
To get started, visit the Pabbly Connect homepage and sign in or create an account. Once logged in, navigate to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button to initiate the setup process.
  • Click on ‘Create Workflow’ in the top right corner.
  • Name your workflow, for example, ‘Create Live Webinar Registrant on Razor Pay Payment’.
  • Select a folder to save your workflow, such as ‘Automations’.
After setting up your workflow, you can define the trigger and action steps. The trigger will be Razor Pay, and the action will be Live Webinar, facilitating the integration through Pabbly Connect.
3. Configuring the Trigger with Razor Pay
In this step, you will set Razor Pay as the trigger application. Select ‘Razor Pay’ and choose the trigger event as ‘Payment Captured’. This event will initiate the workflow whenever a payment is successfully processed.
Once the trigger is set, Pabbly Connect will provide you with a webhook URL. Copy this URL to link Razor Pay with your Pabbly Connect account. Navigate to your Razor Pay account settings, find the Webhooks section, and add a new webhook using the copied URL.
  • Go to Razor Pay account settings and select ‘Webhooks’.
  • Click ‘Add New Webhook’ and paste the webhook URL.
  • Select ‘Payment Captured’ as the active event.
After saving the webhook, Pabbly Connect will wait for a response to confirm the connection. You can test the integration by making a test payment.
4. Setting Up the Action Step with Live Webinar
Next, set up the action step in Pabbly Connect to connect with Live Webinar. Choose Live Webinar as the action application and select the action event as ‘Create Webinar Registrant’. This step ensures that when a payment is captured, a new registrant is automatically created in your Live Webinar account.
To connect Live Webinar with Pabbly Connect, click on ‘Connect with Live Webinar’ and grant the necessary permissions. After establishing the connection, select the specific webinar where the new registrant should be added.
Choose the webinar from the dropdown menu. Map the registrant’s details such as name and email from the Razor Pay payment response. Select ‘Yes’ to send confirmation to the registrant’s email.
Once all details are mapped correctly, save the action step. This completes the setup of the integration between Razor Pay and Live Webinar through Pabbly Connect.
5. Testing the Integration
To ensure everything is functioning correctly, perform a test payment using Razor Pay. After completing the payment, check your Live Webinar account to see if the new registrant has been created successfully.
Refresh the attendees list in your Live Webinar account, and you should see the new registrant’s details reflecting there. This confirms that the integration via Pabbly Connect is working seamlessly.
By automating this process, you ensure that every payment made through Razor Pay results in an immediate registration in your Live Webinar account, enhancing the experience for both you and your attendees.
In this tutorial, we explored how to integrate Razor Pay with Live Webinar using Pabbly Connect. This setup automates the registration process for your webinars, ensuring a smooth experience for your customers. By following the steps outlined, you can efficiently manage your webinar registrations and focus on delivering great content.
